100 Series Landcruiser TD Fuel Filter
Submitted: Sunday, Nov 13, 2011 at 08:55
ThreadID: 90072 Views:4460 Replies:2 FollowUps:1
I regularly change the under bonnet filter but have been told there are two more in main and sub tanks. Has anyone changed these and does it require draining and removing the tanks?
Reply By: Member - Tony H (touring oz) - Sunday, Nov 13, 2011 at 10:12
Hi Harry,
What you are refering to are probably the filter screens fitted to the fuel pickup pipes in the tanks.... these are non-serviceable (in regular service) & only ever checked if tank sender units are removed for some reason.
The filter screen is fairly course (filter anything bigger than half a house brick out).
Just keep changing your under bonnet filter on a regular basis.
AnswerID: 469900
Follow Up By: peter m26 - Sunday, Nov 13, 2011 at 17:45
Hi harry
Tony is dead rigth , don't bother with the fuel pick up screen unless you get are load of dogy fuel , stick with the under bonnet
cheers peter
FollowupID: 744374
Reply By: harry & the hobbit - Monday, Nov 14, 2011 at 07:13
Thanks for that Peter & Tony
AnswerID: 469971
