Trail-a-Mate jockey wheel
Submitted: Monday, Nov 14, 2011 at 14:47
Member - Ralph & Anne C (NSW)
We are looking to purchase a trail-a-Mate jockey wheel for our caravan which weighs in at just under 3 ton loaded and is a purpose built of road van.
Do any of the members have any comments on them as we would love to hear your what you think.
Ralph
Reply By: Member - Rick P (NT) - Monday, Nov 14, 2011 at 15:43
Hi Ralph & Anne
We got one this year and it's the best thing we ever bought, because we mostly
free camp it makes it very easy to level the van attached. Our van is 3 ton as
well, not sure whether it's worth $300 but that's what we paid for it, you might be able to get cheaper on ebay.
Safe travels
Rick P
469998
Reply By: Member - Tony H (touring oz) - Monday, Nov 14, 2011 at 18:04
I love
mine lifts & supports the Kedron very easily.... MUCH easier to use than wind up jockey wheel
470012
Reply By: Member - iijmartin - Monday, Nov 14, 2011 at 21:08
Hello Ralph and Anne,
We use one on our 2.8 t van. Easy to use. One word of caution - we use the flat foot plate instead of the wheel. Be careful that the van does not roll slightly when lifting off tow vehicle as the lower leg has been known to bend.
One guy suggested putting the foot plate onto a block of wood with a piece of plate steel screwed onto the block. This allows the two metal surfaces to slide against each other should the van roll an inch or two.
Otherwise worth the money.
Ian
470040
Follow Up By: Member - Josh- Tuesday, Nov 15, 2011 at 09:45
Hi Ian, Just a
point of interest, shouldn't the
wheels have chocks under them to prevent it from moving at all. Doing anything without chocking the
wheels would be dangerous and asking for trouble.
Josh
744525
Reply By: Member - Julio C (VIC) - Monday, Nov 14, 2011 at 22:02
Hi Ralph & Anne, I got one 2 months ago, very very happy with it. Got
mine at repco $265.00. Cheers
470047
Follow Up By: Member - Julio C (VIC) - Monday, Nov 14, 2011 at 22:05
Check out the Trail-a-mate cable system on ebay, so you never have to take it off. ( works great )
744491
Reply By: Nomadic Navara - Tuesday, Nov 15, 2011 at 01:29
There is a new player on the block - see
http://www.parts4vans.com.au/ - It's a bit cheaper than the Trail-a-Mate. Have just taken delivery of one. It has a lock/catch on the leg so you can carry it in the jockey wheel clamp and the leg will not creep down.
470056
Reply By: ChrisK - Tuesday, Nov 15, 2011 at 08:52
Get one, you'll never regret it. I have had one for over 5 years & it's used all the time with our van. Best thing I ever invested in,
well maybe not the best but still close. Makes things easy and I'm all for that.
470063
Reply By: white pointer - Tuesday, Nov 15, 2011 at 16:29
i was wondering how you go using this jack with a poly coupling (tregg) which can be a bit fiddly to line up heightwise.
what i would like to know is when you jack it up how much lift per 1 pump of the handle?
if you can understand what i mean
cheers phil
470091
Reply By: Member - Ralph & Anne C (NSW) - Wednesday, Nov 16, 2011 at 17:25
Thanks to all who replyed to my question Re: Trail-a-Mate I apreciate the time taken to reply and look forward to catching up in the great outdoors.
470180
Reply By: Andrew M7 - Monday, Nov 21, 2011 at 16:51
Hi all,
I have had a Hijacker for approx. 6 months and it has never failed and worked a treat......I have also noted that they are currently $235.00 plus postage on their website www.parts4vans.com.au
I would never go back to a crank style jockey wheel as they are too hard on the back and shoulders. My van is a 25ft Sterling and I love the Hijacker because it makes life soooo much easier. I broke 2 standard jockey
wheels when we first got the van because they simply cant lift the required weight.
Just my opinion, but all of the larger vans should come with a hydraulic jockey wheel as standard to help us all out??
Have fun.
470571
