Two/four stroke engines – servicing after down-time
Submitted: Tuesday, Nov 15, 2011 at 15:39
ThreadID: 90116 Views:3399 Replies:4 FollowUps:2
I have a Honda 20 generator (4 stroke) which has not been used for three years. Sadly, while I thought I had done so, the fuel was not drained from the tank before it was put away. I know what happens to fuel left for that long so I am wondering just what I need to do before I start-up the unit again? Any mechanics out there with sound advice please.
Reply By: Member - Troll 81 (QLD) - Tuesday, Nov 15, 2011 at 15:54
I am no mechanic but I would drain the old fuel out of the tank and also in the bowl, change the oil and sparkplug and fire her up.
AnswerID: 470085
Reply By: member - mazcan - Tuesday, Nov 15, 2011 at 16:01
hi gordon
old fuel left usually slowly evaporates leaving an orangey/ yellow gum in the carby that can cause the fuel needle and seat to stick which is part of the fuel float inlet assembly it will probably need cleaning and also the gum sediment will be in the fuel bowl and the fuel in the tank will also need to flushed out
you may be lucky if the engine was stored in a cool place and had a reasonbly full tank during the 3 year period
but if it was in a hot shed with not much in the tank
i have no doubt that there will need to be a cleaning of the above parts you may have to buy a spray can of carby cleaner from an auto stockist if realy gummed up but otherwise new petrol and a brushmay/ will do to clean the parts
cheers barry
AnswerID: 470086
Follow Up By: member - mazcan - Tuesday, Nov 15, 2011 at 16:03
hi
carby jets as well may/will need cleaning
FollowupID: 744548
Reply By: Bushranger1 - Tuesday, Nov 15, 2011 at 16:08
G'Day Gordon,
Yep. Sound advice already given.
Do not try to start it with the old fuel. I used to repair small engines & one of the biggest service issues is stale fuel gumming things up. I use a product branded STA-BIL fuel stabilizer to keep the fuel going off. There is another brand available from outboard motor suppliers but I can not recall the brand name.
Stu
AnswerID: 470088
Follow Up By: peter m26 - Wednesday, Nov 16, 2011 at 20:27
Hi guys
stu is right , so are all the others , good tips
you may have to clean the carby , being are honda there is nothing easyer
cheers peter
FollowupID: 744660
Reply By: Ross M - Saturday, Nov 19, 2011 at 23:36
I am a mechanic and forgot to drain the carby for a few months. This gummed the idle circuit and it took me some time to clear it all out. Probably beyond some people without some degree of skill. It is not a standard carby on a Eu20 Honda.
Speed control is done via a servo motor and idle circuit is non removable idle screw. The very small holes got blocked and hard to clean out. I modded mine to get it out and adjusted it after running again.
Hope this helps.
Ross M
AnswerID: 470458
