Discovery TD5 vs Jackaroo
Submitted: Friday, Nov 18, 2011 at 22:29
James G1
Gday
im looking at a jackaroo 3.5l v6 and a lad rover discovery td5.
i beleive that the td5 is better off road (open to 2nd opinions). but im just wondering mainly how reliable the td5 is as i know that some discos can be unreliable.
Thanks heaps
Reply By: Member - Tony S (WA) - Friday, Nov 18, 2011 at 23:23
First up James, what year is the Disco and how many Km has it done?
Tony
470386
Follow Up By: James G1 - Friday, Nov 18, 2011 at 23:27
175000 and its from the year 2000
744851
Reply By: MartyB - Saturday, Nov 19, 2011 at 09:24
Hi James,
I have a 2000 TD5 Disco with about the same kms. I have had it for a couple of years and am happy with it. Before that I had a earlier V8 Disco for about 6 years. I am probably biased but I would have the Dsico over the Jackaroo any day.
The Dsico's seem to be as relaible as any other similar 4WD, parts can be a bit expensive, but not too bad. The first Dicso the only major problems I had with it was the air conditioner died and cost a heap to fix. Also a
fuel injection relay died and stuck me up once.
With the TD5 the only major problems so far have been a diesel regulator block and the
water pump have both had to be replaced. Plus a wierd problem of oil creeping up the wiring loom from the injectors.
As with anything find a good mechanic and keep the servicing up to it and it will be reliable.
The TD5 is a 7 seater, but the rear seats are only suitable for kids, any kid over about 14 will complain about sitting in the back.
from Marty.
470398
Follow Up By: Member - Tony S (WA) - Saturday, Nov 19, 2011 at 12:31
Thanks James,
Mine is a '99 ES Auto is chipped and has done 270 od thousand kays.It averages around 10.2 km/ l without the van. Yes I had a few problems mainly a head replacement. I will not go into the detais except to say that the new owners of landrovers were the problem there. I have replaced the injector wiring loom and a
water pump.
If you do buy it there are two things I would have checked and that is to have the oil pump bolt checked an make sure it has been locktited in. The second thing is the spin filter bolts make sure they have not been over tightenedand partialy stripped. If they have, get your service bloke to put helicoils in.
As Marty says they are just as reliable as any other vehicle with computers.
As for the Jackarro, the B in L has one it is reasonably thirsty and he also had a few problems.
Tony
744881
Reply By: paulnsw - Saturday, Nov 19, 2011 at 13:39
Availability and parts for Jackaroo is a financial and finding nightmare.
470411
Follow Up By: CSeaJay - Saturday, Nov 19, 2011 at 20:18
+1 experience - terrible - double and triple the cost of my wife's BMW at the time
744928
Follow Up By: James G1 - Monday, Nov 21, 2011 at 14:54
Whilst looking through other review websites, i found that a lot of people get parts off eBay, so have a look on there
745067
Reply By: James G1 - Saturday, Nov 19, 2011 at 23:30
Righto
So you would say the disco, but pretty much do the checks and make sure you look at the log book before buying?
470457
Follow Up By: AlanTH - Sunday, Nov 20, 2011 at 12:22
Check aulro.com James and you'll find an answer for everything Land Rover on there.
Not a Disco but I had a Td5 Defender and the only problem I had was the throttle potentiometer playing up.
Actually the real problem was getting it fixed not the defect itself.
Cheers.
AlanH.
744986
Follow Up By: James G1 - Sunday, Nov 20, 2011 at 12:45
cheers mate ill check that out soon
744989
