Gas build up in Batteries??
Submitted: Saturday, Nov 19, 2011 at 20:23
Axle
Doing some terminal cleaning and a general clean up around the battery area on a machine ,...Never think a battery can't blow up!!!,..when putting the last lead on there was a tiny spark, and K.BOOOOOM!,blew the top clean off this battery,very lucky i didn't cop the lot in the face, scared the BJeezus out of a Bloke, the ears where ringing ten mins later, I think the ignition switch was on accessories which gives power to the inside cab light and radio, whether that caused the spark i'm not sure,but sure as hell made me wary of what can vent out of a battery..lol.
Cheers Axle.
Reply By: Member - Boo Boo (NSW) - Saturday, Nov 19, 2011 at 20:57
Hey Axle
Perhaps we should swap names? LOL
Good thing you didn't cop it in the face.
470442
Follow Up By: Axle - Sunday, Nov 20, 2011 at 10:44
Lol mate!!, might be a good idea!
744971
Reply By: Ross M - Saturday, Nov 19, 2011 at 22:27
G'day Axle
Its good you are ok. Yes hydrogen and oxygen mixed in exactly the right proportions do go off. had that experience too.
In most vehicles there is a clock or radio memory and nothing else switched on. This means there is a capacitor which wants to charge when batt connection is made. So a spark occurs. If you want to be safe make yourself a small test light with a clip on both leads.
First connect test light lead to the battery terminal and then at a distance away connect to the heavy batt lead with the other.
Now the spark at the batt terminal has been neutralised and you can fit and tighten the batt heavy lead. No explosion.
Be safe
Ross M
470450
Follow Up By: Axle - Sunday, Nov 20, 2011 at 10:46
Will certainley keepthat in mind
Ross, thanks.
Axle.
744972
Reply By: Rockape - Sunday, Nov 20, 2011 at 08:37
Axle,
best I ever saw was a bloke put a screwdriver across a cat battery to see if it had charge in it.
Well yes it was charged and bits of battery went everywhere.
Have a good one,
RA.
470470
Follow Up By: Axle - Sunday, Nov 20, 2011 at 10:48
I'm not that bad RA,..LOL., But yep they can go off!.
Cheers Axle.
744973
Reply By: Meggs - Sunday, Nov 20, 2011 at 12:29
Does happen but not often. You have to have a couple of things going against you, battery has to have been recently on charge and you have just the right
fuel air mix and the air
fuel mix must have been just right around the battery terminal as hydrogen is lighter than air and disippates very quickly.
470486
Reply By: The Bantam - Sunday, Nov 20, 2011 at 15:48
Um this battery..was on a machine...was it in a bit of an enclosed space.
Explosions from battery fumes are uncommon if the battery top is in wide open air..unless you get realy close with the ignition source to a open cell top.
The gasses can get away.
But it does not take much to confine a good charge of gas arround the top of a battery.
lots of batteries are far to much enclosed in some uses for my liking.
Often if it is a screwtop wett cell battery that has recently been on charge, there can be bubbles of gas clinging to the plates inside the battery....and they will sit there for some time till you bump the battery then they all rise to the top and come out the vents all at once.
Unlucky....or maybe not....you could have very easily ended up blinded and disfgured for life.
I recon you will be waveing ya hat arround a bit before you connect batteries in future.
Better still......try and get this gear over to "sealed" batteries.....there may not be any such thing as completly sealed batteries....but the sealed ones present a far far lowrer risk with this sort of thing.
OH...btw.....if you want to do that again...I know a few musicians who would like to sample the KA bOOOOM fr a drum sound :)
470495
Reply By: Member - Bucky - Monday, Nov 21, 2011 at 06:45
Axle
Yes mate, need to be a bit carefull there !..
I fuse everything I can at the battery, and then insert the fuse last.
I also put the earth on last.
Never mix spark and battery (hydrogen) BIG BANG THEORY
that reminds me
I played a joke on my Brother in Law, on King Island, some 5 years back, when I smoked.
You see, he generates his own power there, on his 300 acre property.
It's a combination of solar, and diesel generator, into a rather impressive bank of re buildable batterys. All thru an invertor. He is a sparkie by trade.
Back to the joke...
Went down to the generator shed, some 100 mts from the house, and he is checking battery's, and believe me, you could smell the hydrogen,
So yours truley whips out a smoke and a lighter, and caught his attention, just as I brought the lighter up to the smoke..
I learnt new SWEARWORDS, and laughed my head off, as I caught him out..
He is still trying to figure out how to get me back.
Cheers Bucky
470535
