Winch gear box grease
Submitted: Tuesday, Nov 22, 2011 at 21:40
ThreadID: 90242 Views:3478 Replies:4 FollowUps:5
Has any body had their winch off and overhauled it. If so what type of grease did you use to repack the gear box planetary gears. The one that I'm playing with is an old Thomas 8000 lb [Ramsey].
Murray
Another Mexican
Reply By: Fishing Barb - Tuesday, Nov 22, 2011 at 21:44
i use a marine water profe greasedarwin dave
AnswerID: 470692
Follow Up By: Member - Murray R (VIC) - Wednesday, Nov 23, 2011 at 20:56
Thanks DAve
Another Mexican
FollowupID: 745257
Reply By: Capt. Wrongway - Tuesday, Nov 22, 2011 at 22:35
Aussie made "True Blue" marine grease. Most boating shops will have it. Comes in tins or tubes.
Capt.
AnswerID: 470698
Follow Up By: Member - Murray R (VIC) - Wednesday, Nov 23, 2011 at 20:57
Capt
Thanks also for your suggestion
Murray
Another Mexican
FollowupID: 745258
Reply By: Member - Alastair D (NSW) - Wednesday, Nov 23, 2011 at 17:43
Murray,
I had an old Thomas winch which I only gave away recently. It used oil in the reduction g/box - but it was ~30 years old.
As said by others I use a moly loaded marine grease. The same as is used on Mercruiser legs.
AnswerID: 470741
Follow Up By: Member - Murray R (VIC) - Wednesday, Nov 23, 2011 at 20:55
Alaster
The marine grease sounds good,
Cheers Murray
Another Mexican
FollowupID: 745256
Reply By: Bonz (Vic) - Wednesday, Nov 23, 2011 at 18:05
Just had mine done/did mine Muz, used plain old moly bearings grease, its done the trick
AnswerID: 470742
Follow Up By: Member - Murray R (VIC) - Wednesday, Nov 23, 2011 at 20:52
Hi Bonz
Looks like a moly based grease is the go and a marine grade seems to be the go also.
OT sounds like you had a good weekend the other week.
Murray
Another Mexican
FollowupID: 745255
Follow Up By: Bonz (Vic) - Wednesday, Nov 23, 2011 at 22:00
Great weekend mate and if you seek out Dust Devil, he has a pot pf that grease he would prolly share a bit of
FollowupID: 745274
