Air bags for Triton
Submitted: Saturday, Nov 26, 2011 at 07:38
Member - Jim K (QLD)
Gooday Folks
I have just returned from a 3 week shake down trip with my wife. one of the things on the to do list is to lift the rear
suspension on our 2010 MN GLXR diesel Triton. We are thinking that we would fit good quality air bags and with this in mind and after researching we think the best way to go is to buy from Trucksprings in the USA. Has any member bought from this source and what kit no did you buy for the Triton. All info on this subject would be welcome and highly appreciated. Jim K
Reply By: nick - Saturday, Nov 26, 2011 at 08:26
Have a search on the net regarding Tritons bending the chassis, right where the air bags are mounted. The problems seems to be that with the air bags holding the vehicle up so easily, you tend to put too much weight over the back of the axle and then bends the chassis.
On a three month trip we had earlier this year, we saw 5 Tritons, 1 BT50 and read on a
forum about another triton all bending and all with air bags.
470969
Reply By: member - mazcan - Saturday, Nov 26, 2011 at 10:39
hi jim k
id stay away from air bags
nicks warning is correct
triton in particular bend the chassis just in front of the rear front spring brackets/hangers
the tail bends down and opens a v gap between front and rear cabs and is a sorry sight
and they do it more if you have a lot of gear attached the the rear end like extra spare
wheels side saddle
water tanks behind the rear axle larger or extra
fuel tanks etc and longer tow hitches
no air bag salesman will take the responsibility for the above problems because you give the ok to fit the air bags so you carry the can if it bends
it your call
you would be safer having a set of lifted spring fitted that way the normal type springs can go up and down as they were designed to do by mitsubitshi
putting air bags over and on the axle is like fitting a chock of wood in there it
reduces the normal leaf spring compression and transfers the the flexing forward of the front rear spring hanger resulting in bending the chassis
cheers barry
470974
Follow Up By: member - mazcan - Saturday, Nov 26, 2011 at 10:49
hi jim k
just found one thread on the above problems
thread number 81850 search and see for yourself aslo if you google search triton bent chassis problem you will get a heap more threads to look at
745510
Reply By: Bushranger1 - Saturday, Nov 26, 2011 at 12:46
G'day Jim,
Like everyone says do not use the air bags!
They might be ok on a Patrol or Cruiser that has a bigger cross section chassis but not advisable on the smaller utes for reasons already explained.
Best to do a proper
suspension upgrade so as to keep the weight on the proper designed load points of the chassis.
Stu
470983
Reply By: Member Andys Adventures - Saturday, Nov 26, 2011 at 13:09
Image Could Not Be FoundHi Jim, I have air bags on my new 2011 mn Triton S/cab and have put Iornman
suspension on and have got duel spare
wheels,
long range fuel tanks,
water tanks and towing trailer with no problems. The air bags only have 25 psi in them and it rides great or bad roads. See photo
470985
Follow Up By: Bushranger1 - Saturday, Nov 26, 2011 at 13:21
Jim,
The air bags are more succesfull when used on a single cab such as this one due to the more central location of the rear axle.
Also I notice that Andy has upgraded the
suspension & keeps the air bag pressure down a bit so looks like a real good setup.
Still would be very reluctant to use air bags at all if yours is a dual cab though.
745529
Reply By: luhuanhuan l - Saturday, Nov 26, 2011 at 17:26
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule
Forum Moderation Team
471007
Reply By: Member - Frank P (NSW) - Saturday, Nov 26, 2011 at 17:28
Think about where the stresses are. With leaf springs the weight of the rear end bears down on the front bush and the shackle at the rear. Two points sharing the load, maybe a metre apart. The chassis is designed for that.
You put an airbag in the middle and load the truck, in addition to the weight being carried by the front bushes and rear shackles, a lot will be carried in the middle by the airbag. This introduces a tendency for the chassis to bend where the airbag is, something for which it was not designed and it might crack there.
If there's a lot of weight behind the rear axle there will be a tendency to lift the front of the vehicle with the airbag as a pivot point. Again, the chassis was not designed for that, it was designed to have that load spread over two points. So cracks in front of the spring hangers could be induced.
Tread carefully.
471018
Reply By: Member - Jim K (QLD) - Saturday, Nov 26, 2011 at 21:54
Thanks Guys I will not be fitting air bags. A lot more thought is required.
Jim K
471050
Follow Up By: Lex M - Saturday, Nov 26, 2011 at 22:51
I see you're in Qld. If you're in
Brisbane, I suggest you have a word with Mayne Springworks.
They've been there forever so they must do something right.
They did a top job on my dualcab toyota at a very good price.
745578
Reply By: landed eagle - Saturday, Nov 26, 2011 at 23:25
The lads at newtriton.net might have some info .
471054
