Suspension bushes - lifespan
Submitted: Saturday, Nov 26, 2011 at 08:55
steve21
Hi All.
what would be a fair lifespan for a set of bushes, had them changed June 2009 my car L/C 80 has done maybe 5-6000km mostly road, never hard off road bashing. had the bearings changed this week and they over tighten the hand brake causing a violent vibration in the rear, caused by worn bushes, they showed my they are starting to perish ... i thought they would last longer! next question anyone know good replacement set? thanks n regards Steve
Reply By: Frank W1 - Saturday, Nov 26, 2011 at 09:23
My 2001 LC105 has now done 186,000k and at last service was advised that bushes are showing signs of wear....like you no off roading like the old days, but general wear & tear. Nearly died at the price of genuine replacements....$80 each, so we have that little cost to overcome shortly.
There are aftermarket kits, usually in a non rubber composition which may last longer, but have a harsher ride and not a supple.........if you are in NSW suggest you contact ALLSPARES 4x4 in
Newcastle you advertising they can supply rubber bushes at $45 each, they don`t say if genuine, but will be investigating that for sure.
470973
Reply By: Rockape - Saturday, Nov 26, 2011 at 11:20
Steve,
Have a look
HERE
RA.
470978
Reply By: Markthemilko - Sunday, Nov 27, 2011 at 00:44
Hi Steve,
I bought & fitted parabolic spring set (3 spring leaves) for the rear of my L/C 2007 VDJ79 (V8). The cost of 3 pairs of bushes for both sides (=a set) were $50 (APM non-genuine parts). (And the 'u' bolts were $7.50c each including nuts - compares with genuine ones @ $50 +2 nuts @ $3 ea.!!)
The springs are a great improvement on the old ones - greater load bearing & smoother ride. But the front bushes didn't last 15,000kms, and to make matters worse the bolts had grease holes which weakened them, making the 14ml bolt equal to about 11ml . On the Anne Beadell one bolt broke in 2 across the grease hole, leaving the larger half in the bush. Fortunately I found a bolt in my spares that got us home. Dismantling the other side at home revealed that the bush was worn through and was sitting on the spring. The spring supplier promptly replaced the bushes and the 14ml bolts with 18ml ones, free of charge.
Think I'll take a spare set of bushes on my next long trip!
Happy travelling!
471058
Reply By: Member - DingoBlue(WA) - Monday, Nov 28, 2011 at 12:24
Had new 'red' synthetic bushes fitted to my 60 series with grease nipples. Have travelled a fairly hard 10,000k's (Gunbarrel, Anne Beadell,
Oodnadatta etc.) and found the bushes have split.
I remembered reading somewhere that the rubber bushes are much better for corrugations etc. so I will be going back to them.
471182
