smoking patrol
Submitted: Saturday, Nov 26, 2011 at 11:19
ThreadID: 90300 Views:6951 Replies:7 FollowUps:19
my 2007 auto crd patrol emits huge amounts of black smoke form the exhaust, it has been to nissan and some "specialst diesal tuning " centres none are able to make any improvement. Has anyone had similar or can suggest a cure ???
Reply By: member - mazcan - Saturday, Nov 26, 2011 at 12:08
hi
hate to tell you this
but its close to internally exploding like they are well known to do go on the patrol forum and read all about it
good luck
AnswerID: 470982
Follow Up By: Member - peter r (NSW) - Saturday, Nov 26, 2011 at 12:41
its not ready to blow up. black smoke means there is more fuel than the amount of air,just finding the cause is the slow process
FollowupID: 745523
Follow Up By: Bushranger1 - Saturday, Nov 26, 2011 at 12:51
Yep different symptoms if it's about to "grenade"
I would be testing the injectors. Get it looked at sooner than later because a bad injector may be causing ring wear by allowing the oil to wash off the cylinder walls because the fuel is not being vapourised correctly.
FollowupID: 745525
Follow Up By: fisho64 - Saturday, Nov 26, 2011 at 17:18
black smoke from a diesel
Before doing any of the above check
-airfilter and intake
-turbo is actually boosting
after that it gets a little more complex
Dont assume that the halfwit apprentice Nissan put on it will have checked anything.
FollowupID: 745549
Follow Up By: louie the fly - Saturday, Nov 26, 2011 at 18:41
This post has been read by the moderation team and has been moderated due to a breach of The Foul Language Rule .
Forum Moderation Team
FollowupID: 745558
Follow Up By: fisho64 - Saturday, Nov 26, 2011 at 19:14
thanks for the stroppy reply, I would have said the same as you as an apprentice.
I'll concede it should have read "Nissan may have put on it"
But Im sure you are aware that it was a semi "tongue-in-cheek" generalisation of the the worst case scenario for this guy who appears to have been abandoned by Nissan. A vehicle just out of warranty and Nissan say they cant fix it? My point was dont assume that they have checked what they should have before spending money elsewhere to start from scratch again.
Yes I am a qualified tradesman.
Your customers shouldnt be talking straight to an apprentice, in theory. They are supposed to be under the direct supervision of a tradesman.
You talk to the tradesman and he tells the apprentice what to do then checks its done.
Have you ever had a bill from a dealer with a charge rate for an apprentice? Id wager not. So what do these apprentice do?
We know what they do, starting with the simpler jobs generally, except you get charged for a tradesman still.
Thats exactly what appentices are meant to do but due to a shortage of tradesmen the supervision often doesnt take place as it should.
Best watch the swearing also or you'll get "moderated"
FollowupID: 745562
Follow Up By: Bonz (Vic) - Sunday, Nov 27, 2011 at 08:59
Fisho, I agree with the sentiment but its the half wit supervisor that is at fault not the apprentice. Supervision is the key not the skills of the individual.
I have had my Patrol to Nissan for a 60000km service and back two days later to get it done properly as had found stuff not done. Funnily it never ran as well as when I picked it up the second time.
FollowupID: 745590
Follow Up By: louie the fly - Sunday, Nov 27, 2011 at 10:38
I suppose the difference is that some companies don't provide quality training. The places I've worked have given good training. Part of good training is also developing the apprentice's ability to be able to interact directly with customers. Depends on what industry you're in. I'm not in the car repair industry. I do know that some employers take on apprentices because they are cheap labour. Training apprentices is my 'raw nerve'.
I didn't realise I'd written anything disimilar to what I've seen on here ountless times before. My bad!
FollowupID: 745601
Follow Up By: pepper2 - Sunday, Nov 27, 2011 at 18:33
fisho thankyou for your reply,have checked all those things
FollowupID: 745636
Reply By: Rockape - Saturday, Nov 26, 2011 at 13:07
Peps,
they will probably find s sensor has failed and the computer thinks the air to fuel ratio is lean thus giving it bulk fuel.
Just a word of warning. Running diesels that rich does do damage and causes internal temps to rise quite a bit. Lean out a petrol and you can blow a piston, over fueling a diesel can do the same thing.
If it was mine I would not be driving it and getting it to a mechanic with a very light foot.
Hope it all works out for you,
RA.
AnswerID: 470984
Follow Up By: member - mazcan - Saturday, Nov 26, 2011 at 13:19
hi rockape
thats exactly what i was eluding to - over fueling- this washes the oil of the cylinder walls and the rings and pistons will melt really quick
FollowupID: 745528
Follow Up By: member - mazcan - Saturday, Nov 26, 2011 at 13:25
hi
followed a nissan smokep/trol in perth on tuesday couldn't see where i was going for black smoke bouching out it's tailpipe it was overfuelling as well and will blow up too
FollowupID: 745530
Follow Up By: pepper2 - Saturday, Nov 26, 2011 at 13:37
thankyou for your reply,its been to sevreal mechanics ,including nissan and a specialist near berrima none have improved it. Its air to fuel ratio is 17 to 1 which i am told is correct,turbo boost is normal,which sensor do you think it might be?
FollowupID: 745533
Follow Up By: TerraFirma - Saturday, Nov 26, 2011 at 14:00
Can't believe the mechanics can't sort this for you. Diesel Engines aren't complicated.
FollowupID: 745536
Follow Up By: Rockape - Saturday, Nov 26, 2011 at 14:35
Mate,
I don't know which sensor but if it had 17:1 air fuel ratio it would not smoke.
I still suspect a sensor as something is telling the ECU it needs more fuel.
If you haven't tried it already ask the question on the patrol forum, it maybe an intermittent problem.
again hope you can sort it out,
RA.
FollowupID: 745538
Follow Up By: pepper2 - Sunday, Nov 27, 2011 at 09:20
air to fuel ratio has been measured and confirmed at 17 to 1, injectors have been checked and are ok the vehicle has approx 90000ks only.
FollowupID: 745592
Reply By: luhuanhuan l - Saturday, Nov 26, 2011 at 17:23
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
AnswerID: 471004
Reply By: Member - Scrubby (VIC) - Saturday, Nov 26, 2011 at 20:16
G`day Pepper2,
I have just recently had my 60 series L/Cruiser to the doctor for the same reason.
Diagnosis was a "stuck valve in the injector pump ????"
( I am not a diesel mechanic so the doctor lost me.)
Anyway apparently this valve is to allow extra fuel available when the engine is being started and then returns to a lesser amount when the engine is running.
BUT because this valve was stuck in "the extra fuel mode" it was over-fueling by heaps, thus great clouds of black smoke.
Remedy..... The old girl had done 340,000 klm and had never had the injectors or the pump serviced so it was a simple decision to have the whole system over-hauled.
Outcome............. No black smoke and it runs like a newbie.
Hope this may help,
Regards,
Scrubby.
NB
Sir Kev and Dave B will recall I had this problem with the vehicle while at the Silverton Gathering.
AnswerID: 471042
Follow Up By: Bonz (Vic) - Sunday, Nov 27, 2011 at 09:02
Bet mine smoked better than yours at Silverton Scrubby!
FollowupID: 745591
Follow Up By: pepper2 - Monday, Nov 28, 2011 at 10:12
Scrubby what was the cause of your patrol smoking at silverton?
and i checked with nissan and am advised nissans have a similar valve for cold starts in fuel pump they have agreed to have another look at it this week.
FollowupID: 745702
Reply By: Bob Y. - Qld - Saturday, Nov 26, 2011 at 22:27
Why not try some diesel additive, if nothing else has worked. Something like Chemtech "Diesel Power" or similar.
Won't damage anything, and if it is a stuck valve in the pump, as suggested above, the formula might be enough to free it. Even a 250mL bottle, in a 90L tank, won't do any harm.
Hope you get it sorted,
Bob.
AnswerID: 471052
Follow Up By: pepper2 - Sunday, Nov 27, 2011 at 10:15
thankyou for your reply tried that no difference
FollowupID: 745597
Reply By: Member - Chris & Debbie (QLD) - Sunday, Nov 27, 2011 at 11:59
Hi Pepper
You have not stated when it blows black smoke which makes it hard to suggest anything that may help with the problem.
Does it blow smoke all the time or only during acceleration, towing, up hill or at start-up? Do you see it in the rearview mirror when driving or someone who has followed you mentioned it?
Chris
AnswerID: 471094
Follow Up By: pepper2 - Sunday, Nov 27, 2011 at 18:31
it blows smoke all the time the higher the load the more smoke,easily seen in rear view mirror,i towed a light capmer last weekend it has black soot across the front and down left hand side.when towing it is atrocious...Does anyone know what was the result of the patrol smoking at silverton????????
Fuel consumption is high approx 5 to 6 klm /litre around town NOT towing.
Seems like overfuelling as apparently everything checks out,the reply above about the toyota having a valve in the fuel pump is worth a thought,dont know if nissan has the same.
Thankyou for your replies.
FollowupID: 745635
Reply By: Member - Bentaxle - Sunday, Nov 27, 2011 at 13:14
Pepper 2
Check your Air filter & fuel filters and more importantly the Mass Airflow Sensor (MAF), take it off and clean it or replace it (about $290, lot cheaper than new engine). The MAF measures the airflow passing over it and signals the ECU which then adjusts fuel flow accordingly. To clean the sensor is a 10-15min process using aerosol Contact C leaner or MAF Cleaner both available from Auto Accessory shops
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 471108
