Petrol 98
Submitted: Saturday, Nov 26, 2011 at 14:18
Member - sangster(Vic)
Hi all, was wondering what people think of using petrol graded 98 for my
xtrail,(2002) I have duel
fuel (LPG) run mostly on LPG...I'm led to believe that by running on 98 (realise there's a price difference) it will give you more k's per 100
my thinking is that pulling a van it might be a better proposition... any thoughts please
Stan
Reply By: Member - MUZBRY(Vic) - Saturday, Nov 26, 2011 at 14:51
Gday
The easiest thing to do would be to try a tankfull. I run my old nissan on 98 when out in the bush, only because i need all the help i can get.
470990
Reply By: member - mazcan - Saturday, Nov 26, 2011 at 15:02
hi sangster
id check with nissan that the motor is capable of withstanding the extra heat from the higher octane petrol
you can burn valves and piston tops from using the wrong petrol in an older motor that may not have been designed to burn 98 octane
fuel
after all 2002 is 9yrs ago ??????
cheers barry
470991
Follow Up By: patsproule - Saturday, Nov 26, 2011 at 15:49
The higher the octane the cooler it runs actually.
Unless the X-Trail runs a knock sensor, has a reasonably high compression ratio, and has enough ECU relarn scope in the ignition timing to make use of the 98 octane I wouldn't bother.
Pat
745543
Reply By: ross - Saturday, Nov 26, 2011 at 16:22
High octane does not change the energy content of the
fuel,it only stabilises the
fuel burn under compression in high compression engines.
If your engine is not knocking,you dont need it.
Even it did give you better
fuel economy it would have to be in the range 7-8% to cover the extra price of the 98 ron over the 91 ron.
And if it did give better economy,the oil companies would be advertising that it did to get people to buy it.
470997
Reply By: luhuanhuan l - Saturday, Nov 26, 2011 at 17:22
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule
Forum Moderation Team
471001
471002
Reply By: olcoolone - Saturday, Nov 26, 2011 at 19:04
I wouldn't bother running your Xtrail on 98..... the benefits will be not noticeable.
We have two cars that have to run on 98 and if 95 is used you notice the difference.
471034
Reply By: Member - sangster(Vic) - Saturday, Nov 26, 2011 at 19:17
Hi all, Looks to me from all that has been said I'd be better staying with what I'm using unleaded super... and the LPG... thank you all for your input, am very grateful for them, yes the Xtrail is 9yrs old and still running like a dream... pulls the van beautifully, I only drive on the black . Bit long in the tooth now to go off road with all the new gear ones needs, but I wish all the very best to those who are able to do same..
Cheers to all
Stan
471036
Reply By: Member - Phil G (SA) - Sunday, Nov 27, 2011 at 11:08
We had a 2005 xtrail and got about 0.4 l/100k extra from 98 octane compared ro standard.
471080
Follow Up By: Member - sangster(Vic) - Sunday, Nov 27, 2011 at 12:05
Hi Phil,
Thanks for that, my son has the 2005 xtrail running on 98 ron ..
but with the advice I have been given will stay with the status quo
Stan
745607
Follow Up By: Member - Phil G (SA) - Sunday, Nov 27, 2011 at 13:36
Yes, we ran 98 because we only did 10,000k per year with the Xtrail and the extra cost wasn't an issue. But if 98 is 14 cpl extra, then not worth the extra money. It also takes a few tanks before any benefit is seen. Both our vehicles are now diesel so we now wonder about Ultimate vs normal diesel :-)
745616
Reply By: Kimba10 - Sunday, Nov 27, 2011 at 12:07
If you believe everything these current affair shows do, they did a test on 91,95,and 98 octane fuel, how it burns and the wether it was worth the extra $$ to fill up, the best out of them all was the 95, equal to the 98 in terms of fuel useage L/per 100.. I never buy 98, infact I nearly always buy 91 as alot of the servos here have reintroduced it as they were having problems getting the E10 due to supply problems and alot of people have gone off buying the E10 as its not economical based on the extra you use compared to the couple of $$ you think you save when buying it. I wont run E10 crap in any of my cars even my wifes which is meant for it, I have done fuel comparisons on her car and still the best is 95 normal unleaded by about 20 over normal 91 unleaded, if I use E10 I lose pretty close to 50 to 60k out of the
tank, I am basing this on Litres used per 100 not just a guess each time I fill up and this is only on a baby
tank, her cars holds (going by books) 43L so to lose 50k from 1
tank is a huge difference, could imagine how much les klms I would get out of 180L of E10 in my prado,.............
471096
Follow Up By: Member - sangster(Vic) - Sunday, Nov 27, 2011 at 12:56
That's very interesting
Kimba, thanks for that , losing 50 to 60k out of a
tank is a horrible thought I to wouldn't use E10 either.
regards
stan de man
745614
