Help with the remote control for 2003 Nissan Patrol
Submitted: Monday, Nov 28, 2011 at 16:16
P and JM
Hullo all,
Is there anybody out there that has had the following problem with their remote control for a 2003 Nissan Patrol ? I must point out, the vehicle has not been used for a couple of months.
Remote would not flash indicators and open doors,
a new battery was recommended and replaced.
remote control still does not operate flashers and open doors.
Ant ideas or suggestions greatly appreciated.
Thank you P&J
Reply By: Notso - Monday, Nov 28, 2011 at 16:30
Does the key operate the vehicle normally otherwise, Do the lights flash etc when you open the door with the key?
471195
Follow Up By: P and JM - Monday, Nov 28, 2011 at 16:42
Hi Notso,
Key still unlocks normally and indicators do not flash when using key to open doors.
745734
Follow Up By: Notso - Monday, Nov 28, 2011 at 16:54
The problem might be in the module, have you checked the fuses?
745738
Follow Up By: P and JM - Monday, Nov 28, 2011 at 17:05
I just tested the spare remote and all is ok.
Will have a look and clean original with electronic cleaner and see how it goes.
Thanks for the thoughts
745739
Follow Up By: P and JM - Monday, Nov 28, 2011 at 17:27
No still no go so any help will be appreciated. Thanks
745741
Follow Up By: Notso - Monday, Nov 28, 2011 at 18:45
It is just possible that the remote has lost it's code and may need reprogramming by a dealer, if the second one works Ok it might be worth a try before buying a new one,about $150.00 a few years back.
745752
Follow Up By: P and JM - Monday, Nov 28, 2011 at 22:49
Yea, I have been looking on the 4x4 site and it appears it could come up with a new programmed code or what ever and maybe different to the spare.
It appears to me it's only covering replacement remotes and not originals to be reprogrammed to original code.
I will have another read 2morro. Cheers P&J
745786
Reply By: Dave(NSW) - Monday, Nov 28, 2011 at 17:45
P&J.
This is a common problem with GU patrols,
Mine will unlock with the remote but wont lock. There's plenty of info on here
http://www.patrol4x4.com/forum/
about it. Most seem to get an after market alarm fitted then use that remote.
Cheers Dave.
471208
Follow Up By: P and JM - Monday, Nov 28, 2011 at 20:51
Hi Dave,
I had that suspicion with it being Nissan, like all their gear "FAULTY" and all they say is buy a new one or give us your wallet.
Will have a look on Patrol 4x4. Thanks for your help.
Cheers P&J
745763
Reply By: anglepole - Tuesday, Nov 29, 2011 at 09:39
Hello,
You can re-program your key your self. Go to your local library and get a Workshop Manual for your GU. It will guide you step by step. It does not have to be a genuine manual.
Conversely you can do search on the
http://www.patrol4x4.com/forum/ I have seen the process shown there.
Good luck
471267
Follow Up By: P and JM - Tuesday, Nov 29, 2011 at 14:12
Thanks anglepole, but what I need to know is: by re programing it will it be the original code and be the same as the original spare one?
This is what I need to know. Going to local library and to get a manual for it could be the weeks joke in the bush.
Regards P&J
745856
