Computer Mount
Submitted: Monday, Nov 28, 2011 at 16:54
ThreadID: 90343 Views:2782 Replies:5 FollowUps:16
G'day all,I would appreciate any input on the problem of mounting a small (10.1 in) computer in the GQ Patrol ute, used for OziExplorer mapping.
I currently have it sitting in a whatsit box in the centre seat position but it's literally a pain in the neck to reference.
I have seen a platform mounted on a gooseneck and fastened to the windscreen by dual suction cups, which on first glance would seem OK, but I doubt that the gooseneck would stand any dirt roads without slowly descending the load to the dash. Has anyone used one of these and how have you found them? I have seen them supplied by a UK company on the net.
Alternately, has anyone found a mount that will survive Aust roads without collapsing. Your input is appreciated.
Reply By: Member - nick b - Monday, Nov 28, 2011 at 17:09
Gooday Tom C : have you looked at " ram mounts " they are well made ,I have a Ram gps mount & i find that excelant !!!
also if you go to GPS aust site/ forum have a look at " show off your project " some good stuff on that .
cheers nick
AnswerID: 471202
Reply By: Mick O - Monday, Nov 28, 2011 at 17:22
Mate I had a similar issue and ended up getting a unit made for the GU Pootrol and then again for the new Landcruiser ute. I have utilised a RAM laptop tray and articulating arm. Mount fits to the existing seat and console mounts. Incredibly robust. Brown Davis in Melbourne made both for me.
Click on my profile beside my profile picture below. As there is a picture or two in the photo section.
Cheers Mick
AnswerID: 471204
Follow Up By: vk1dx - Tuesday, Nov 29, 2011 at 10:40
Hi Mick
What does the passenger say about it mate? My wife said absolutely no way so we got a unit in the dash.
Was there any problem with rego?
FollowupID: 745825
Reply By: Member - Craig F (WA) - Monday, Nov 28, 2011 at 18:22
Hi Tom,
I have used the RAM mount system i bought the "RAM-B-316-1-202U" this mounts to the bolt holding the seat rail to the car. You then need the corect sissor arm and mount to suit your laptop. I have used mine over a wide variety of terain. It works a treat. It is also adjustable so I can move it to suit the wife or myself and I can also remove it very quickly. The locking force on the rubber balls is more than enough to stop any movement.
Craig
AnswerID: 471211
Reply By: Member - John and Val - Monday, Nov 28, 2011 at 22:41
Tom,
Don't know how applicable this might be to your vehicle, but here's what we've done in our Troopy.
A Laptop is the wrong shape to share cabin space, so for years we used a 9" touch screen mounted centrally on the dash, connected to a small computer running OziExplorer, located behind the passenger seat. The screen was hung in a flexible sling from a plinth on top of the dash, so that it was free to move around relative to the vehicle on corrugations and worse. Surprisingly, this worked very well and never gave any trouble in 200,000+ km, including countless rough and corrugated tracks.
When space became too precious to waste on the computer we obtained a slate (tablet) computer (10" screen) that took the place of the previous touch screen. The whole computer and screen is little bigger than the old touch screen, and again, hangs down the front of the dash. It has yet only done one big trip, but has survived.
The issues - 1) Dashboard real estate is valuable and very limited, so the tablet hangs in front of the radios, which is not ideal, though not a serious inconvenience. 2) Screen brightness is barely adequate in bright sunlight. 3) - important - the screen must be a low reflectance type to avoid seeing little more than your codriver.
I'll post some photos when the system lets me .
HTH
J and V
- Albert Einstein
AnswerID: 471234
Follow Up By: Member - John and Val - Monday, Nov 28, 2011 at 22:49
Ignore the background stuff. It's not a part of the installation.
Image Could Not Be Found
J and V
- Albert Einstein
FollowupID: 745785
Follow Up By: Member - nick b - Tuesday, Nov 29, 2011 at 06:52
Gooday J&V : I would be interested to know where you got your touch screen from or any other info ,
cheers nick
FollowupID: 745798
Follow Up By: Member - John and Val - Tuesday, Nov 29, 2011 at 07:29
Nick,
The touch screen came from Hong Kong through ebay quite a few years ago now. It was similar to this one and may have been 8", rather than 9". I wanted a 4:3 aspect ratio ( not the newer wide screen format), and at least 1024x768 native resolution in a touch screen. Those requirements narrowed the field down to one or two.
It has been replaced by the HP TC1100 shown in the photos. This is considerably larger though not as bright as the previous screen. It came second hand through ebay.
J and V
- Albert Einstein
FollowupID: 745802
Follow Up By: Member - Phil G (SA) - Tuesday, Nov 29, 2011 at 12:19
I'm with John,
I've had an in dash 7" pop out screen for many years and my computer slides closed into a pocket next to my seat.
A simple VGA 7" screen costs about $70 delivered on eBay. Bigger screens and touch screens are a bit dearer. I recently bought an 8" VGA touch screen for $138 delivered but haven't installed it yet. These screens also have composite video inputs which are ideal for reversing cameras.
I've seen a lot of computers installed on mounts and personally find it is too big an intrusion on interior space in my vehicle.
FollowupID: 745838
Follow Up By: Member - nick b - Wednesday, Nov 30, 2011 at 09:15
Thank you for your reply's J.J.V: would or are your monitors working on windows 7 ?
I had another idea of using a pc tablet ,something about the same size 7"..8"
do you any thoughts on that !!!
cheers nick
FollowupID: 745941
Follow Up By: Member - John and Val - Wednesday, Nov 30, 2011 at 11:02
Nick,
Most computers will have provision for an external monitor, and there are lots of 7” and 10” monitors available and suitable for our purposes. Provided the computer itself can run Windows 7 there should no problem using it with a dash mounted screen to run OziExplorer. One trap – some of the less expensive computers will only run the Andoid operating system, not windows. I believe that an Android version of Ozi is in the pipeline, but so far as I know is yet to arrive. (Can someone more in touch comment on this please.)
If you want a touch screen, the choice of monitor becomes a bit smaller. The touch screen is a big advantage when travelling as a mouse becomes unusable when the vehicle is moving, especially on corrugations!
A tablet/slate style computer combines the computer, display and touchscreen in the one neat little unit the size of the monitor. The downsides – limited range of screen sizes and usually it’s widescreen, which really means reduced height rather than increased width. (I reckon a square screen would best for gps!) Some are confined to Andoid – cheaper but pretty limited if you want to run windows stuff. I think the ideal size is probably 9” – our 10” is inconveniently big, and many are 7” which I think is a bit small to display good detail. Last point – don’t leave valuables visible when you leave the vehicle – bit hard if it’s a big computer stuck to the dash.
Suggest do an ebay search on “tablet” to see the big range now available. “tablet windows” will give you a much smaller listing.
I think if I was setting up again, I’d aim for a 9” tablet running windows, with a good bright screen, at least 1024x768 resolution, and the screen non-reflective.
J and V
- Albert Einstein
FollowupID: 745955
Follow Up By: Member - Craig F (WA) - Wednesday, Nov 30, 2011 at 16:45
Image Could Not Be FoundImage Could Not Be Found
10" tablet running windows 7, works a treat. Applications are easy to get. I am running Window 7 with Microsoft Office 2010 and Oziexplore. It is mounted Using a RAM mounts and a generic cradle. I bought it whilst in China. The website "madeinchina" is a good start.
Craig
FollowupID: 745987
Follow Up By: Member - nick b - Wednesday, Nov 30, 2011 at 22:40
Thanks again John & Craig for your great help in this . My notepad pc has windows 7 , but the only shop in Adelaide that I have found (jaycar) don't guarantee that the touch software will work windows 7 & wont give any info ( $250.) So when a mate said about the tablet I thought this maybe a better option !!!!
I was hoping to get one from a shop rather than ebay /Internet...
cheers nick
FollowupID: 746035
Follow Up By: Member - Craig F (WA) - Wednesday, Nov 30, 2011 at 23:04
Hi Nick,
To add to my set-up I also have a bluethooth keyboard its 150 x 60 mm saves me having to lean over whilst driving!!!!
As for the tablets you will pay more from a shop but for piece of mind a good option if not comfortable with the net. I would suggest a shop like Harvey Norman.. Why??? I recently took a two year old laptop into HN Port Hedland WA dropped it on the counter with no receipt then picked it up 10 days later fixed. It was purchased from Perth. For those that travel I think its a good service. I was also told that if it went back to Perth early that they could re-direct it to a different store..
Craig
FollowupID: 746036
Follow Up By: Member - John and Val - Thursday, Dec 01, 2011 at 07:28
Nick,
Craig's bluetooth option is a good one, especially if your present laptop is already set up with bluetooth. Small bluetooth (or wireless) keyboards that include a pointing device (touchpad, trackball, etc) are available and as Craig says are very convenient. We've used one too, though it's a trackball type and we find that the trackball is very sensitive to corrugations. Many of them are very small too, too small for mature age fingers. Here's one that would tick most of my boxes - big enough to be usable, with a touchpad so it has a mouse function without being mechanically sensitive. (I fully understand your reluctance to use ebay but it's a very good catalogue!)
J and V
- Albert Einstein
FollowupID: 746047
Follow Up By: Member - nick b - Thursday, Dec 01, 2011 at 10:25
question : If you have a wireless /blu key board is there any benefit/.... have a touch screen ?
Craig : when you say ... bluetooth keyboard its 150 x 60 mm saves me having to lean over whilst driving !!!! where do you have the key board & why ?
thanks nick
FollowupID: 746062
Follow Up By: Member - John and Val - Thursday, Dec 01, 2011 at 11:30
Nick,
If you have some pointing device you do not need the touch screen, which increases your monitor options. A bluetooth or wireless keyboard/touch pad is a very flexible alternative. Craig's keyboard, at 150x60mm would be too small for me. We use this one which is 230x90 mm, big enough to be easily usable, small enough to carry in the overhead console. As said, I wouldn't recommend ours because of the the mechanical sensitivity of the trackball.
One comment on wireless stuff. Some of it runs on infrared, like the remote controls for your TV, and other video gear. Infrared isn't suitable in the vehicle because its directional, but either bluetooth or wireless is fine.
J and V
- Albert Einstein
FollowupID: 746071
Follow Up By: Member - Craig F (WA) - Thursday, Dec 01, 2011 at 12:04
Hi Nick,
The touch screen is great..... but. As I'm running windows 7 I have installed programs that were primarely made for keyboard operations. Can still do it by the touch screen but find this keyboard great. Its small enough to sit in my door compartment.
FollowupID: 746074
Follow Up By: Member - nick b - Thursday, Dec 01, 2011 at 14:40
thank for your feed back it has been very helpful :-)
FollowupID: 746083
Reply By: Tom C - Wednesday, Nov 30, 2011 at 17:03
Many thanks to you all for the suggestions you have offered. I'll sit down now with a rough red and go through them in detail and look up references. The RAM mount seems excellent at first glance. Once again, thanks all.
AnswerID: 471367
Follow Up By: Black Cobra (WA) - Thursday, Dec 01, 2011 at 01:18
G'Day Tom,
I have used the RAM mounts in the F250 and you cannot go past them as the one I used was the one that you can cut and bend the arms to whatever shape you desire to fit around any obstacle like the centre hump in the floor.
The lifetime warranty with RAM mounts is spot on as after a few years one of the ball mounts snapped whilst doing the Anne Beadell and the suction cap of the windscreen mount that holds my GPS would not stick properly.
Rang the GPSOZ store and they said send them back and they would be replaced free of charge including frieght and the new ones were here in a few days time and that after 4 years use.
I use a 10" Panasonic Toughbook computer which is the ideal size for reading whilst travelling and the Toughbook can be used as a normal computer and when I put it into the adjustable Toughbook tray that is mounted to the RAM mount its coverts to a tablet computer with digital tough screen.
Also it has a shockproof hard drive that is good for rough terrain as it can take the knocks and bumps and can also be removed at the flick of a catch and stored away from the computer so that if it gets knocked off you just get a new computer and slide in the hard drive.
Below are a couple of photos.
Stewart
Just like the cobra we will twist and wind all over this great land called Oz.
FollowupID: 746043
