2000 Explorer noise
Submitted: Wednesday, Nov 30, 2011 at 13:24
ThreadID: 90378 Views:1811 Replies:2 FollowUps:2
We have 2000 Explorer that has started making a noise when put under load e.g going up a steep hill or towing the van up a hill. Noise and slight vibration can be felt on passenger side footwell. Normal driving all is quiet. Thought it was transmission but was checked all OK.Anyone had this problem or have any suggestions.
Reply By: Andrew - Wednesday, Nov 30, 2011 at 13:39
You haven't described the noise but as there appears to be a localised vibration aswell it could be worth checking your engine and transmission mounts as they can give those symptoms that only appear under load. Also worth checking driveshaft joints for same reason.
Perhaps a description of the noise?
A
AnswerID: 471358
Follow Up By: ross - Wednesday, Nov 30, 2011 at 18:49
Yes and the exhaust system is also a prime suspect for rattles and vibration noise under load
FollowupID: 746003
Reply By: Member - DAZA (QLD) - Wednesday, Nov 30, 2011 at 15:42
Google Ford Explorer problems re: vibrations and you will find lots on info.
Most of it is on a few USA forums, but it will give you plenty of reading.
AnswerID: 471362
Follow Up By: Mark&Sue - Thursday, Dec 01, 2011 at 08:22
G'day Brian sorry to wreck your day , but stop driving explorer immediately and get it checked out , they have a bad habit of breaking timing chains and therefore wrecking the engine , so get someone to diagnose asap.
FollowupID: 746051
