Need help with hubby's Christmas pressie (tyre deflators)
Submitted: Monday, Dec 05, 2011 at 19:12
ThreadID: 90465 Views:3275 Replies:9 FollowUps:8
I am going to get my Hubby a set of tyre deflators for Christmas, but am unsure of the brand to buy and is there anything special I need to ask for as I am often treated with disdain by the people behind the counter or salesman as I am female. So if you can help me I would really appreciate it. Thanks for all the help guys
barb
Reply By: Member - Barry H (WA) - Monday, Dec 05, 2011 at 19:49
Barbara,
Just cruise into your local 4WD shop and ask for a set of Stauns.
Top quality deflators, hubby wiil be happy and the 4WD guy will know that you know what you are talking about.
Barry H
AnswerID: 471757
Reply By: Member - Toyocrusa (NSW) - Monday, Dec 05, 2011 at 20:17
Hi Barbara. Have a look here also. There are a few varieties. Cheers,Bob
AnswerID: 471759
Reply By: Member - Tony V (NSW) - Monday, Dec 05, 2011 at 20:20
Barbara,
You might consider an ARB deflator in place of the Stauns, I have both.
The Stauns are preset and not easily adjustable, where as the ARB deflator can be used to deflate to any pressure. Both about the same price.
A couple of vids to help you decide.
My preference would be the ARB unit.
AnswerID: 471760
Follow Up By: Member - Tony H (touring oz) - Monday, Dec 05, 2011 at 21:30
Ditto for the ARB unit
FollowupID: 746499
Follow Up By: Crackles - Monday, Dec 05, 2011 at 21:44
I too have both but no longer use the Stauns. The ARB tyre deflator (also sold under several other brand names) is faster particually for large tyres & far more flexable when you want to change pressures to something other than what the Staun is preset at.
Cheers Craig.............
FollowupID: 746501
Follow Up By: Member - Richard W (NSW) - Tuesday, Dec 06, 2011 at 06:20
Barabara,
Agree. My Stauns have sat unused in the glovebox for years.
FollowupID: 746509
Follow Up By: Dave... Adelaide (SA - Tuesday, Dec 06, 2011 at 22:57
Barbara
Another vote for the ARB, if you were to ask where my Stauns are , i dont think i would be able to tell you....lol
Cheers.......Borgy
FollowupID: 746560
Reply By: Member - barbara M (NSW) - Monday, Dec 05, 2011 at 20:46
Hi Everyone,
thanks so much for help, everyone here goes beyond the expected amount of help. Once again thanks so much.
Barb
AnswerID: 471762
Reply By: Member - Rowdy6032 (WA) - Monday, Dec 05, 2011 at 20:57
Depends a bit what the Hubby will be using them for.
The Stauns are great for dropping your pressure before driving on the beach. They are pre-set at 18 PSI from the factory and can adjusted.
They come in a pack of 4 and I believe some people have 2 adjusted for sand and the other 2 adjusted for gravel or whatever. I have left mine at 18 PSI and they take no time at all to drop the pressure before going on the beach.
For adjusting pressures for driving on gravel etc with car and trailer/van the ARB deflator with the gauge would perhaps be a better option as you can drop the pressure down to whatever you think is right at the time.
There are other products around but I have only used the above.
AnswerID: 471766
Reply By: rumpig - Monday, Dec 05, 2011 at 23:04
i have Stauns and have just replaced them with the ARB E-Z Deflator.
the Stauns are good but IMHO the E-Z tyre deflator allows for better changability of different tyre pressures. i've had my Stauns stick a few times and not stop at the set pressure also, so having a compressor handy also helps.
AnswerID: 471776
Follow Up By: Dave(NSW) - Tuesday, Dec 06, 2011 at 11:25
I had the same problem with Stauns sticking and dropping the pressure to low.
I also changed to the ARB E-Z Deflater as you can drop tyre pressures to any thing that suits the situation.
Cheers Dave.
GU RULES!!
FollowupID: 746523
Follow Up By: Robin Miller - Tuesday, Dec 06, 2011 at 12:50
Had the same issue also - had a look at mates ARB deflator and it worked but is fiddly with removing the valve, wouldn't like to trust it in adverse conditions.
We deflate tyres about once a week and need no stuffing around so these days we use the 3 way air pressure guages with inbulit deflator.
2 of these have proved to be faster and much more precise.
The quick acton of rotating the stem means you can check current pressure easily , by the time you have attached the second one the first is almost ready to remove so nett effect is a faster more accurate system for 4 tyres.
FollowupID: 746530
Follow Up By: Member - Rowdy6032 (WA) - Wednesday, Dec 07, 2011 at 17:10
For those having a problem with the Stauns the link below may assist.
Staun Tyre Deflator Hints
FollowupID: 746631
Reply By: Member - Craig F (WA) - Tuesday, Dec 06, 2011 at 12:31
I too have both the Strauns and ARB.
I always use the ARB. I can drop to what every pressure suits and it is quicker than the Strauns.
Both good solid products one is more versatile.
Craig
AnswerID: 471805
Reply By: Member - Geoff M (VIC) - Tuesday, Dec 06, 2011 at 12:31
Hi Barb,
Another option for deflators are the one's available from ABR Sidewinder - link here
No affiliation, just a happy customer.
Cheers, Geoff
AnswerID: 471806
Reply By: desray (WA - Wednesday, Dec 07, 2011 at 04:10
You might want to look at http://www.youtube.com/watch?v=Fc_hV1dgHW4 also .. Made in WA
AnswerID: 471845
Follow Up By: Member - Craig F (WA) - Wednesday, Dec 07, 2011 at 14:28
These are a good tool but are out of date with what is now available. Why count then try to get it the same 3 more times. You can now get a Guage fitted to the tyre deflator!
FollowupID: 746606
