Wednesday, Dec 07, 2011 at 18:31
@ Marty,
charging voltage is only one side of the equation.
In the OP's case it looks like the Delkor was subject to deep cycling which kills any flooded battery rather sooner than later.
That's because deep cycling causes the grids inside the battery to expand/contract which squeezes out a little bit of active material on every cycle. And that's an effect not related to charging voltage.
@ Dunc,
Optimas are a different kettle of fish in that they're sealed VRLA batteries which can actually build up enough internal pressure to make them swell. The overpressure relief valves are useless if the battery case softens due to high ambient temps. The battery case expands before the valves see enough pressure to vent.
Remember what it feels like, using your lungs to inflate an air balloon?
It requires lots of pressure to get the first puff of air into them. But once they start to grow bigger, it becomes easy work.
This is how it works with the overpressure relief valves.
Either they open during the early stages of heating when there's max pressure, or they don't in which case, even at decreasing pressure, the battery continues to swell.
Ross,
..I tried a fully charged, wet 100a deep cycle once before to start the diesel and it barely turned it over.
Why would a AGM 100A do any better?..
Batteries constantly lose capacity after having reached their peak early in their life. It's like filling up a
fuel tank which slowly but steadily shrinks in volume - the
fuel gauge (voltmeter) signals full, but the actual amount of
fuel (Ah and cranking power) remains unknown.
So your wet 100Ah deep cycle (there is no such thing BTW), may have lost much of its original oomph which led you to the wrong conclusion.
A new and
well maintained 100Ah battery can deliver all the current you want for cranking at above zero temperatures.
...Im just confused as to why the newer larger battery gave up the ghost 1st...
Three possibilities:
1) it was subject to deeper discharges more often than your starting battery was.
2) it could have been exposed to more shocks and vibration if it was mounted closer to the axle than your starting battery.
2) it was a dud from beginning on.
cheers, Peter
746649
