Bars for Roof Top Tent
Submitted: Thursday, Dec 08, 2011 at 07:23
ThreadID: 90515 Views:2666 Replies:2 FollowUps:0
When I head west next year I am borrowing a roof top tent from a mate of mine. This will mean getting some bars for my roof and I wonder what sort of load rating I will need to worry about. From what I can gather the load rating refers to while you are on the move and you can put a lot more weight (e.g. my body while sleeping) on it. Is this the case? What load rating would you recommend? I have a GU IV Patrol.
Reply By: Tim - Thursday, Dec 08, 2011 at 13:50
I usually look at this forum regularly but seldom do I reply. Anyway as no one else has I thought I would help you out.
The loading of the racks is probably not the issue but the loading of the gutters may be. From memory they are rated at 100kg. Whether that is per gutter or in total is anyones guess (might state in the vehicle manual). As you stated, this is a static weight and not a dynamic weight which means 100kg on the roof when you are parked. Depending on the shape of the load, at speed it may increase or decrease downwards force.
Personally, I installed 3 factory toyota roof racks to spread the weight out just a bit more then the standard 2 bars and had no dramas. I think the bars were rated around the 100-120kg mark. When you start looking at the racks I found they fitted into 3 categories. Very light, standard and heavy duty. The heavy duty ones are made from gal plate and are typically used by tradies and I wouldn't trust the light ones with my surfboard.
Hope that helps.
Tim
AnswerID: 471958
Reply By: Member - Garth (NSW) - Thursday, Dec 08, 2011 at 20:48
Holden4th,
I've always used four racks for the rooftop tent, just because it felt a better spread and seemed solid when two of us moved around in the tent. I have Rhino Sportz racks rated at 90kgs each.
regards
Garth
AnswerID: 471997
