landcruiser models
Submitted: Friday, Dec 09, 2011 at 11:06
ThreadID: 90542 Views:2543 Replies:4 FollowUps:0
would any member know what the different letters & numbers represent re toyota landcruisers? HZJ105RGXL UZJIOOR VDJIOORHDJIOORGXL l will be on the lookout for a 100 series 4.2lt turbo diesel auto approx 2002 - 2006 and need to know the correct model number. Thanks and regards.
Reply By: Member - Tezza Qld - Friday, Dec 09, 2011 at 11:36
Hi Magic2
If you go to lcools website they will have all the information you require.
I think you have to join but it;s free
www.lcool.org/
Cheers Teza
AnswerID: 472060
Reply By: Sir Kev & Darkie - Friday, Dec 09, 2011 at 12:38
The Model Number for a Factory TD 100 Series is the HDJ100 after that it could be GXL etc which nominated the trim level.
UZJ100 is the V8 (4.7l) Petrol version
HZJ105 is the 4.2 NA Rigid front end diesel version
FZJ105 is the 4.5l Rigid Front end petrol version
Hope that helps
Cheers Kev
Russell Coight:
AnswerID: 472064
Reply By: Member - Phil G (SA) - Friday, Dec 09, 2011 at 14:04
As above, you want the HDJ100 - the "HDJ" bit means it has the very good 1HD-FTE 24valve EFI factory TD motor. The "100" says it has independant front suspension.
Beware that it is common to fit an aftermarket turbo to a HZJ105 and then advertise it as a "turbo diesel". The end result is nowhere near as good as the factory TD. The "HZJ" says it came originally with a normally aspirated diesel(1Hz) motor and the 105 says it has a live axle front end.
AnswerID: 472071
Reply By: magic2 - Friday, Dec 09, 2011 at 20:52
thanks TEZZA, SIR KEV, DARKIE and PHIL G. The information is exactly what i was after. Thanks and Regards.
AnswerID: 472103
