use laptop for gps
how do i go about using my laptop as my gps. what do i have to purchase regards vicbar57
Reply By: Member - Duncan W (WA) - Friday, Dec 09, 2011 at 20:02
GPS mouse and appropriate mapping software, such as Ozi Explorer loaded onto your laptop. Ensure good power supply ideally independant from your cranking battery.
Cheap as chips to set up and a GPS mouse I've found is more reliable than your standard GPS with regards to maintaining satellite contact.
Dunc
AnswerID: 472098
Follow Up By: Member - Duncan W (WA) - Friday, Dec 09, 2011 at 20:03
Oh yes forgot to add just look at the related advert that now appears at the side of your post.
Dunc
FollowupID: 746881
Reply By: Member - Joe n Mel n kids (FNQ - Friday, Dec 09, 2011 at 20:10
the "idea" is a good one but in pratice it is a pain in the butt, i only say that as i have done it and gone back......
But to answer your question, you need a usb gismo that picks up the signal and the program (oziexplorer) and the maps and someone who know what they are doing to "connect" it all togeather ........
Now to get back to why i dont like it, the laptop is NOT designed to be bounced around, it is big and dont fit to well anyware, it is hard to use a mouse or pad, it may have a big screen but it is also attached to the keyboard and it all takes up to much room....
So what to do ??????
Buy one of the cheap BIG screen GPS navs on e-bay, make certain it is not "locked" and can be loaded with "oziexplore" and and load all the maps and program and you will never look back, i did and someware on here i have a thread on how to do it, dont ask me ware as i am hopeless at finding "threads" but it is on here as are many other threads about GPS's and so on..
Cheers and good luck
Joe
AnswerID: 472099
Reply By: Member - nick b - Saturday, Dec 10, 2011 at 08:47
Hi Vicbar : I have a hand held garmin gps connected to lappy , I have loaded mapsaurce program & shonky maps a cheap option :Note make sure you get good advice from a supplier I.E like a good map shop !!! you can find a lot of information on shonky maps & down loads from gpsaustralia wed site .
But I would a agree with the thread bulky in a vehicle ,so have a look at post 90343 on gps plus try a search here & google
good luck nick
AnswerID: 472122
Reply By: Member - Rich - Saturday, Dec 10, 2011 at 08:55
I just tried it for fun and with possibility of using it.
The issues raised above against the laptop is true.
However if you want to go down that path look at a solid state device, less likely to be effected by bouncing around.
I had one of those ASUS netbooks and a Bluetooth GPS which I had used with a PDA.
I was able to run Oziexplorer on the netbook and connect to the gps.
I reckon it would work well but they are bulky, battery life is poor so need power supply and would need some heavy duty mounts to support.
All doable but to much of a pain.
I have been playing around with an ipad and have it mounted on the dash, it works well but does not run Oziexplorer. There are a lot of other options in this area.
Rich
AnswerID: 472124
Follow Up By: Member - Duncan W (WA) - Saturday, Dec 10, 2011 at 13:36
Mine is the ASUS EeePC dash mounted and with a dedicated power supply linked to my Axillary battery. Corrugations have rarely been an issue and I've been down some doozies. Made sure that all the plugs are in tight and generally no problems. Also handy for my photo downloads and transfer to external hard drives.
To make sure I don't loose track PLT files I do a manual save whenever I stop.
Dunc
FollowupID: 746927
Follow Up By: Member - Rich - Saturday, Dec 10, 2011 at 14:51
That is what I have.
I wS concerned the bouncing around and dust would effect the rotating disk.
Good to hear it doesn't but that can be just luck sometimes with disks.
I take you save to another device Iike an SD card.
I was looking in to this until I got the iPad. I like the way you can move maps around on the iPad and such like devices.
Android based would perhaps be a good option as can run.
But what you have sounds good. Th emount would be interesting to see
Rich
FollowupID: 746933
Follow Up By: get outmore - Sunday, Dec 11, 2011 at 07:17
Duncan W (WA)
you do realise the track file has a tick box to auto save so as the track is created its saved ? rather than saving it every time you stop
FollowupID: 746995
Follow Up By: Member - Duncan W (WA) - Sunday, Dec 11, 2011 at 13:30
Hi G.O.M yep do realise that but I also do a manual save to be safe. Been caught out in the past. And I also have my F keys set up as well for various functions.
Rich all the mount is is a small sheet of 5 ply a bit larger than the size of the E which is fastened to my dash via a bracket and then anchored down using a home made turn buckle to the edge of my stereo. Use the self adhesive Velcro on the board and a couple of strips under the E. Sticks like you know what to a blanket.
Line it up so that with the screen open it is flush with the windscreen. Biggest issue is glare but a cardboard cut out screen shade does the trick.
Dunc
FollowupID: 747039
Reply By: Member - John and Val - Saturday, Dec 10, 2011 at 14:06
Depends on what you want from the gps. If you want a talking guide around town, then the laptop is probably not the way to go. If though you are looking for mapping in the bush, as said already, it's hard to go past adding Oziexplorer to the laptop and plugging a little mouse style gps into a USB port.
The downside, as already said is the inconvenience of sharing the cockpit with a laptop. Suggest look at a cheap slate style pc rather than use the laptop. A version of Oziexplorer is available to (with some limitations) run under the Android operating system (see here). I haven't tried it, but that should make for a very inexpensive gps with a good screen.
Another thing to consider - Is your laptop bright enough for such use?
J and V
- Albert Einstein
AnswerID: 472144
Reply By: Member - Richard W (NSW) - Sunday, Dec 11, 2011 at 07:02
vicbar,
I have a Dell Latitude ATG (military spec) laptop with a 160gb solid state hard drive. This is mounted on RAM mount. I used to have a bluetooth GPS but replaced it with a GPS mouse. This setup had travelled about 60,000KM on different trips running continuously. The 100 series has quite a bit of space between the front seats and as it's auto I don't need to change gears often.
The setup was a bit exxy but I use the laptop for a myriad of other things like backing up and processing images, writing trip reports on the fly, storing MP3's etc.
AnswerID: 472214
