The answer to keeping an absorption fridge rally cold
Submitted: Saturday, Dec 10, 2011 at 11:36
ThreadID: 90565 Views:5881 Replies:6 FollowUps:7
I recently had trouble with my electrolux 2310 and ended up buying a new dometic but found on gas on a very hot day it still did not keep it cool enough so i got a screwdriver and put it in the slot at the bottom of the exhaust vent and flipped it out to let the heat escape more easily and bingo at 40% the fridge compartment up high did not get above minus 3, so dometic if you read this try and make your new heat vents hinged, everyone else try it you will find your fridge runs a lot colder
Reply By: oldtrack123 - Saturday, Dec 10, 2011 at 11:54
Hi Graeme
You have just found out the basis of gaining the best from any fridge & particular absorption types
THAT is getting the condenser as cool as possible
Adequate ventilation
A draught over the condenser fins either natural or forced with fans can led to a dramatic improvement
Most fridges are not even installed to the makers recommendations
AnswerID: 472135
Follow Up By: Graeme A - Saturday, Dec 10, 2011 at 19:20
Hi oldtrack123
i TOTALLY AGREE.
FollowupID: 746956
Reply By: Member - GeeTee (NT) - Saturday, Dec 10, 2011 at 13:26
I am having drama's with our fridge not pulling down cold enough. Just where did you "flip out the vent". Did you remove the lower plastic vent altogether ?
AnswerID: 472138
Follow Up By: Graeme A - Saturday, Dec 10, 2011 at 19:16
GeeTee
Not the lower vent if you look at the top vent on the right hand side you will see a smaller vent where the exhaust of your fridge comes out there iis a slot at the bottom thats where you put the screwdrivor and it will come straight out also you should have a steel baffle going from the top of the fridge to the body of the caravan at where the top of the vent is so all the heat is directed upward to the vent which most caravans don't have you don't need a fan, the baffle should be the whole width of the fridge. good luck
FollowupID: 746954
Reply By: Rockape - Saturday, Dec 10, 2011 at 13:50
Graeme,
This works really well.
Have a look HERE
Used this on my 3 way and it worked well. I now have a 12v fridge but I still have the fan hooked up to pull air over the evaporator.
Have a good one,
RA.
AnswerID: 472140
Follow Up By: Rockape - Saturday, Dec 10, 2011 at 14:00
Should have added I didn't use the 70deg C thermostat I installed a 50deg one.
FollowupID: 746929
Follow Up By: racinrob - Saturday, Dec 10, 2011 at 15:28
Thanks RA, I will follow this up, it'll give me something constructive to do over the Christmas holidays..... BTW hope you have a good one.
rr
FollowupID: 746940
Follow Up By: Member - David M (SA) - Saturday, Dec 10, 2011 at 15:33
Did much the same Graeme but used a computer fan connected directly to a small solar panel. Just runs all the time.
Dave.
FollowupID: 746942
Reply By: Member - John and Lynne - Saturday, Dec 10, 2011 at 13:51
Hello Graeme
As Peter said, these fridges are often installed incorrectly. When our first one did not cool properly we took it to a Dometic agent for a wrrenty claim. They found there was no insulation packed around the fridge and it was just sitting inside a box surroundes by a large gap full of hot air! The van manufacturer reinstalled the fridge according to Dometic instructions and put a fan in to improve the ventilation. This made a huge difference. So check your installation. (We changed manufacturers second time around!)
Also check if your fridge is Tropical Rated - some people are still selling the non Tropical fridges - fine in Europe but not much good in Australia. The idea of taking off a vent cover is good but you could not do that while travelling because of dust etc. I suspect we would forget to replace it when we left camp!
Another thing is that while travelling and running on 12volt these fridges only maintain their temperature but do not cool. So in hot weather, whenever we stop for lunch or anything taking more than a few minutes, we switch the fridge to gas to cool it down. This works well so the fridge is still cold at the end of the day's travel. Lynne
AnswerID: 472141
Follow Up By: Graeme A - Saturday, Dec 10, 2011 at 19:36
Hi John & Lynne
The Dometic book reccomends insulatiion around the fridge and also the baffle, but as all heat rises as long as you have the bafflle there is no way the heat is going to return around the fridge. You do not take the whole vent cover of just the small one on the right hand side of the upper vent thats why it has the slot at the bottom and it just pops straight back in again also i have battery in van so do not have to worry about changing over.
FollowupID: 746959
Reply By: landed eagle - Saturday, Dec 10, 2011 at 19:53
What material is used for the insulation of the sides of the cabinet. Fluffy stuff or a polystyrene product?
AnswerID: 472181
Follow Up By: Graeme A - Sunday, Dec 11, 2011 at 11:34
Not sure landed eagle you could ask caravan refridgeratin services but i haven't used any as removing the vent when it is really hot and with the baffle along the top of the fridge i don't think you need it.
FollowupID: 747027
Reply By: The Bantam - Saturday, Dec 10, 2011 at 23:26
Every single fridge ever made including the one at home works massivly more efficiently if the external heat exchanger is properly vetilated.
Everybody just want to jam them in the smallest hole they can....
As for 3 way fridges not running well on 12 volts......the majority fail to install heavy enough wire alll the way back to the car battery....thus considerable voltage drop and very poor performance.
AnswerID: 472207
