What split system air can honda 20 run?
Submitted: Saturday, Dec 10, 2011 at 16:42
micky s
Hello I have a caravan that I want to fit a split system reverse cycle air cond on. I wish to use a honda Eu 20i to power it. Does anyone know what would be the best split system air cond I could use which the Honda will be able to handle?
Appreciate any feed back.
Micky
Reply By: Mick O - Saturday, Dec 10, 2011 at 16:53
Mickey,
a common question on the
forum. You'll find much of what you're looking for in this search result thread.
Generator for airconditioner
Cheers Mick
472153
Reply By: Notso - Saturday, Dec 10, 2011 at 18:55
And before you buy anything, try it out on the van first, to be sure, to be sure, to be sure.
472172
Reply By: landseka - Saturday, Dec 10, 2011 at 19:08
A Honda 20i will run ANY split system you would ever want to run in any caravan.
They do struggle on a 40+ deg day (just when you want a/c) with the dinosaur roof mounted, power hungry, noisy & inefficient Dometic style van a/c's.
Most splits of van size in fact will hapilly run on a 1kw Honda.
Cheers Neil
472176
Reply By: white pointer - Saturday, Dec 10, 2011 at 23:53
hi micky our van has a truma climaster reverse cycle air con. under the
seat which the honda 20 runs without any problems. i cant really comment on its cooling/heating performance as we havent used it in very hot or cold conditions as yet.
regs. phil
472209
Follow Up By: LeighW - Wednesday, Dec 14, 2011 at 13:14
The generator rated output is 1600 Watts, it should therefore be able to run a "soft start" split upto 1.6KW
If you thinking non invertor type units I wouldn't go above 1KW.
LeighW
747350
Reply By: LeighW - Wednesday, Dec 14, 2011 at 13:15
LeighW
472516
Reply By: Fatso - Thursday, Dec 15, 2011 at 08:42
G'day Mickey,
I think you are going about this back to front.
If you are just accumulating potentially useless trinkets than go right ahead.
If you want to realy aircondition your van than I suggest you go & find out exactly what size & type of aircon you need first & then from there find out what size & type of power supply you need to properly run that system.
What would be the use of having an aircon that doesn't work when it is hot?
I don't know Jack Sh-t about airconditioning vans & the aircon you can run off a Honda 2.0 might be suitable.
But you will be wasting your money if it is not.
472561
Follow Up By: Member - Andrew (QLD) - Thursday, Dec 15, 2011 at 09:27
Not at all FS if they already own the Honda genset.
Andrew
747401
