Diesel tune up
Submitted: Monday, Dec 12, 2011 at 01:01
ThreadID: 90602 Views:2117 Replies:2 FollowUps:3
Hello once again. We need to get a tune up on our 1998 3lt turbo jackaroo.Can anyone recommend a mechanic on the north side of brisbane.
Thanks Mandy
Reply By: outsider - Monday, Dec 12, 2011 at 04:25
Try village motors at petrie as they are Isuzu specialist and have been great with any problems we have had with ours.
Not too many place have any idea when it come to the 3l td (4jx1 motor) and do more damage then good.
Not a bad idea to check and clean the injector harness connector (next to the oil filler) as it get contaminated with oil which causes the engine to run roughly or not at all.
also make sure you have the correct grade oil in the motor, 15-40w oil commonly used in diesels is too thick for the hydraulic injection system and will cause problems.
AnswerID: 472337
Follow Up By: Member - Porl - Monday, Dec 12, 2011 at 07:00
Hi Outsider, how do you clean the injector harness? with any oil cleaner?
FollowupID: 747106
Follow Up By: MEMBER - Darian, SA - Monday, Dec 12, 2011 at 12:26
I think it should be said that this situation is somewhat bizarre, in that the oil you speak of (inside the harness's union with the supply loom) gets full of black engine oil because the oil is forced back along the INSIDE of the electrical wires themselves, from the injectors ! The union can be disconnected and cleaned out with any solvent that doesn't harm plastics, but the problem will re-emerge.
FollowupID: 747125
Reply By: Jeffrey B2 - Wednesday, Dec 14, 2011 at 16:37
Mandy B Try this number 5482 6411.
This is the number for my Diesel Mechanic in Gympie.
He has serviced all my diesel vehicles since 1986 and I cannot fault his work.
I will drive up there from Brisbane as often as required just to be satisfied my service is comlpete.
He did own a Diesel Jackaroo for some time so i am sure he will know all about yours.
Have fun Haji-baba
AnswerID: 472528
Follow Up By: Mandy B - Sunday, Dec 18, 2011 at 00:17
Thank you for that.
FollowupID: 747613
