Thursday, Dec 15, 2011 at 16:10
I sent a note to Chipit asking about their chip after reading this thread and got a very extensive reply which they asked me to upload. I have no affiliation with them but have been looking in to getting a chip one day i am posting it as it contains a lot of useful info if you are looking for a chip, hopefully others see it that way. I don't know much about them so hopefully this will give you some ideas.
There are also quite a few attachments which i will load up in a subsequent thread.
(sorry cut and paste did not work
well)
The following is from Chipit
Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: LOGO 1
Diesel Performance Solutions
Power when you need it
The Chip It Performance Module Kit is DIY (plug in and drive away) and comes with full instructions on a little thumb drive provided. Installation is therefore easy.
Fuel economy is usually increase by around 7 % depending on how you drive. I (director of Chip It) personally get 5% better economy however I do drive harder than most. Some of our customers do not get any
fuel saving however their module is probably tuned with higher power tunes and they are more than happy with that.
Attached are some dyno results of different vehicles to show what power we get up to. On your vehicle you will get around 30% more torque from our standard tune. ( next thread Richard)
I should point out the many differences between the Chip It Module and our competitors.
On the newer Common Rail engine, the Chip It Module will connect to 2 sensors in your existing factory plugs One is the
Fuel Pressure Sensor (which the other Chip Manufacturer also do) ... the other one is to the Turbo Boost Sensor (which is UNIQUE to Chip It). This second plug connection allows us to control turbo boost as
This gives us
fuel AND air maps to adjust to get the best air/
fuel ratios … which equals better tunes. It also means we are not just dumping a lot of extra
fuel in like others. By adjusting both the
fuel and the turbo pressure it means we also achieve less exhaust gas temperatures and less black smoke due to over fuelling!
If you are purchasing our EGT Controlled Performance Module then this would be the 3rd sensor we are plugging into. (2nd sensor for pre common rail vehicles).
This engine safety feature (again unique to Chip It), is explained in the 4WD Action Magazine Product Review.pdf (attached) and also further down in this email.
A little information on our competitors.
This bit removed by Richard. I will send it to you if you want.
Our Performance Modules are digitally tuned via a laptop computer which means each cell (or load point) is adjusted to suit the right
fuel amount needed for YOUR family of engine and we develop ALL tunes directly on our own in-house dyno. If we need to add a good amount of
fuel in the mid-range and only a little amount at the top end ... we can. Again, other chips cannot as a variable resistor will add
fuel EVERYWHERE by the same percentage.
This professional tuning ability of our Performance Module allows us to better tune your engine and provide higher torque numbers safely.
These are the benefits we have in our favour:
1) More features, including Exhaust Gas Temp monitoring and control, (this feature de-tunes the engine when EGTs get too high)
2) Better tunes … (not only do we address the
Fuel curve, but we also address Turbo Boost Curve (on Common Rail vehicles),
3) Aussie made product, (no other chip sold in Australia is made in Australia)
4) Tuned for Aussie cars with Aussie fuels,
5) Tuned by us with our own in-house dyno... no overseas tunes or non Aussie speaking 3rd party involved,
6) Australian Based Tech Support,
7) Better prices and much better value for money (prices start at $999.00 for NON EGT Controlled power Modules),
8) 30 days money back guarantee,
9) 5 Years warranty,
10) New Vehicle Engine Warranty Option,
11) Custom Tuning (if desired) ... which again, other manufacturers do not have.
Let me expand on point No. 11. As mentioned, our Modules are fully plug in and drive away with no extra tuning required. However, when you wish to have a full custom tune our Module allows this. With all the other Chips on the market, you just turn
the knob on the front panel to increase the resistance value. This then is NOT a “custom tune” to suit your vehicle as changes are NOT made to suit your individual engine’s needs. This is NOT so with the Chip It Module. Real-time tuning capabilities are given to every Chip It Custom Tune Dealer and adjustments to tunes can be provided via email to you the customer … for free and the Chip It Macro Tuning Software allows YOU to flash the tunes to the Module within seconds.
The EGT Controlled Module allow you to run high performance tunes without risk of damage to the engine because the in-cabin display (and data logger) keeps the performance tune in-place ONLY whilst EGTs are at safe levels. It will change to factory standard tune IF the EGT's climb too high. Again, this is unique feature to Chip it.
This feature is highly recommended to those customers that are using their vehicle for towing caravans, boats or other heavy equipment.
We also have 5 years warranty and 30 day money back guarantee.
Check out this video of our Chip.
http://www.youtube.com/watch?v=NSgQp9-TiLU&feature=mfu_in_order&list=UL
Considering the above, you can see that we provide really good value for money and why we are gaining a lot of customers from those who thought that DP Chip etc were the only performance chips on the block.
About engine warranty. Click on this link and go down to the bottom where it talks about the Australian_Automotive_Aftermarket_Association.pdf another link shows the Warranty laws in Australia.
http://www.chipit.com.au/product-info
The first paragraph of page 9 (in that link) explains that Dealers/Manufacturers CANNOT void Statutory Warranty simply from customers fitting aftermarket parts. BTW, I have a NS Pajero and had our Performance Module fitted for the last 40,000kms. No problems and Dealers have seen it. However, I ALWAYS recommend people REMOVE the Module (5 mins work) before going back to the Dealer for any warranty work. For normal service work, find a good local mechanic with whom you can start a good relationship with. He will take care of the vehicle better than the Dealer anyway.
Sincerely,
Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Description: Jumping Triton.jpg
Robert
CHIP IT
Power When You Need It
Office: 1800 78 48 82
Fax: (02) 9807-9000
Address: 50 Buffalo Road Gladesville NSW 2137
Email: sales@chipit.com.au
Web: www.chipit.com.au
Be Green, read from the screen...
********** Confidentiality Notice and Disclaimer **********
This email and any attachments are intended only for the use of the recipient and may be confidential and/or legally privileged.
Chip It disclaims liability for any errors, omissions, viruses, loss and/or damage arising from using, opening or transmitting this email.
If you are not the intended recipient you must not use, interfere with, disclose, copy or retain this email and you should notify the sender immediately by return email or by contacting Chip It by telephone on 1800 78 48 82.
All sales from Chip It are subject to Chip It Terms and Conditions available upon request or viewable on the website www.chipit.com.au
Robert
CHIP IT
Fax: (02) 9807-9000
u
472594
Follow Up By: Member - Rich - Thursday, Dec 15, 2011 at 16:32
here are the attachmennts
Image Could Not Be Found
Some of the attchements could not be loaded as was PDF.
If interested let me know and I can email them to you
missing were
FAQ PDF,
PRODUCT review pdf
Why are EGTs important
747435
Follow Up By: Member - Frank P (NSW) - Thursday, Dec 15, 2011 at 17:05
This is fantastic info, Rich - thank you very much.
I hope it doesn't get moderated for advertising or whatever - it's the kind of info that people who are considering a chip need.
Thanks again
Frank
747437
Follow Up By: Member - Rich - Thursday, Dec 15, 2011 at 17:55
Frank,
No worries I hope you get something out of it.
I have more info which I could not load, pm me with an email address and I will send it to you.
by the way I do not have a chip in my car yet but was looking around and found the chipit guys who seem to be on the ball.
I am not sure I understand it all though :).
Richard
747441
Follow Up By: Member - Captain (WA) - Friday, Dec 16, 2011 at 11:27
In my 200 I have the ChipIt chip and EGT guage. The EGT interfaces with the chip so in the event that the EGT gets above your target (I have set 560C) then the tune reverts to standard.
Normally my EGT stays
well below 550C even when on full throttle, but when towing up say a long
hill with a flat foot and overtaking, then I have had the EGT go above 560C and the tune revert back.
While backing off the accelerator would achieve the same thing, its a great comfort to know that the ChipIt does it automatically if you are not looking at the EGT to notice.
Captain
747507
