Mud Flaps for Patrol 4.2tdi -- where to buy ?
Submitted: Tuesday, Dec 13, 2011 at 20:20
ThreadID: 90632 Views:4641 Replies:8 FollowUps:6
Greetings , over the years have ripped my mud flaps of one by one- now need to get some more, as i have to drag my boat down 15 KM of dirt road before i hit tar , and i kick up a lot of stones :(
Looked on fleabay -- nothing available - is this something i can only get from Ni$$an or are they available as an after market item , and if so - where ?
thanks in advance
Reply By: Begaboy - Tuesday, Dec 13, 2011 at 20:22
oops forgot to add - its a 2000 model -- ( this site needs an edit option )
AnswerID: 472458
Reply By: Uncle-Laurie - Tuesday, Dec 13, 2011 at 20:38
Site LinkGot a set of these on mine , had them for ages and not a problem, very tough.!!
AnswerID: 472461
Follow Up By: get outmore - Tuesday, Dec 13, 2011 at 22:40
and uber cool on the way out to a B and S to boot!
FollowupID: 747306
Follow Up By: Dave(NSW) - Tuesday, Dec 13, 2011 at 23:00
You can get them from West Track the Caterpillar dealer a lot cheaper.
Cheers Dave.
GU RULES!!
FollowupID: 747309
Follow Up By: Begaboy - Wednesday, Dec 14, 2011 at 19:46
Thanks uncle Laurie - the originals were moulded - these ones are not right ? obviously they will have to be fitted differently to the moulded one-
Is it an easy install - ( ie just drill a few new holes and use self tapping screws )
and do they provide same level of protection as the moulded ones ?
thanks for the link - been added to my watch list
BB
FollowupID: 747370
Follow Up By: Uncle-Laurie - Wednesday, Dec 14, 2011 at 20:52
BB I have had these on since 2008 when I was working on a cattle station in the Pilbara. I had lost the others in transit, so I took my time fitting them ( about half an hour each side) and did some trimming to fit them neatly. I also put a length of chain from the bottom of each flap to the steel body work ,just inside the underneath of the brake light. this helps to stop tearing them off when reversing.
hope this helps a bit mate.
cheers Unc
FollowupID: 747379
Reply By: Nutta - Tuesday, Dec 13, 2011 at 22:17
3.0l will fit to if its a gu,
unless theyve got 4.2tdi on them.
AnswerID: 472471
Reply By: The Bantam - Tuesday, Dec 13, 2011 at 22:48
If you can fit plain flat mudflaps, get youself down to your local diesel spares supplier.
They will have plain flat flaps in all sorts of sizes and not exensive.
AnswerID: 472477
Reply By: Member - Nolo (Brisbane) - Wednesday, Dec 14, 2011 at 09:29
I have seen these from Bullzeye.
Bullzeye mudflaps
Regards Greg
AnswerID: 472497
Reply By: Flighty ( WA ) - Wednesday, Dec 14, 2011 at 10:14
Begaboy
Have fitted old conveyor belt rubber to my last 2 vehicles, simply cut roughly to shape and then sand edges smooth, with a grinder.
Has reinforcing already in them and can be kept clean with tyre black.
If you don't have original metal straps, then fit "panel washers" to help with the strength.
You will find belting at any belt supplier/Splicer and they will normally have plenty of left overs and old belt around for spares if required.
Hope this helps
Paul
AnswerID: 472500
Follow Up By: Begaboy - Wednesday, Dec 14, 2011 at 19:50
Flighty , had thought of that option too :) i have access to old conveyor belts but all food grade stuff ( blue too :)
kind of kicking myself that i didn't keep some for when i used to work for CSR in there quarries - they threw away hundreds of metres !!
FollowupID: 747372
Follow Up By: Flighty ( WA ) - Wednesday, Dec 14, 2011 at 20:43
If you are in metro WA I have metres of it lying around the workshop & yard,
Help yourself it has gotta be better than some prices I have seen.
Flighty
FollowupID: 747376
Reply By: Member - Rob S (NSW) - Wednesday, Dec 14, 2011 at 18:53
If your looking for second hand genuine parts try Patrola parts
There wrecking stuff all the time and reasonable prices
http://www.patrolapart.com.au/
Rob
I only ever made one mistake
AnswerID: 472536
Reply By: Begaboy - Wednesday, Dec 14, 2011 at 19:52
Thanks to everyone for your replies - have a few more options now than i first thought i had !
BB
AnswerID: 472538
