digital speedo
Submitted: Tuesday, Dec 13, 2011 at 23:39
ThreadID: 90634 Views:4537 Replies:4 FollowUps:10
i have a 82 hj 47 and i would like to put a digital speedo in it can this be done if so how would i go about it?
thanks
Reply By: mikehzz - Wednesday, Dec 14, 2011 at 01:14
A cheap gps will do the trick. More accurate than a speedo and doesn't care what size tyres you are running.
AnswerID: 472481
Follow Up By: Life Member - esarby (NSW) - Wednesday, Dec 14, 2011 at 06:46
Julian. I have a Hillspeed GPS SpeedO
Just Google (HillSpeed) Very Good.
Bogaard HillSpeed GPS Digital Speedometer
(Product Code: HUD-09)
Description:
This model uses an internal GPS module to provide speed sensing. It is suitable for any of the general applications listed above.
With its "plug and play" design, it can be easily and quickly installed and be operating within a few minutes in any vehicle.
Its over-speed alarm can be set to any desired speed and quickly and easily programmed to give any combination of the in-built audible and visual alarms when that speed is exceeded.
It consists of the Display Module and features:
Accurate speed display in external locations.
Visual and audible over-speed alarms.
Options for plug and play or permanent power connection.
FollowupID: 747320
Reply By: Member - Josh- Wednesday, Dec 14, 2011 at 06:40
You will need to check the regs on changing the speedo. I believe if you change the speedo it must show the same as the original. There are heavy fines for changing the speedo reading. If hte old one still works, what's the advantage of changing to digital??
Josh
AnswerID: 472485
Follow Up By: Life Member - esarby (NSW) - Wednesday, Dec 14, 2011 at 07:31
Josh.t is a known fact that original speedo"s are not correct +/- 5 to 10 K's. I have checked my speed with those road side speed check units and found my speed to be * K's out. I have been pulled over twice for speeding in school zones but have had my Gamin to prove my 40 K limit. I set my Hillspeed to the speed limit and it shows a 4 to 8 Km difference. Still have my clean licence and no points lost.
FollowupID: 747322
Follow Up By: Member - Josh- Wednesday, Dec 14, 2011 at 07:46
Esarby, That may be true, which I already knew speedos arent 100% accurate. In fact manufacturers are allowd more tollerance than we are. Still doesn't change anything. The Law states a speedo must show the origanal KM's if changed.
Josh
FollowupID: 747324
Follow Up By: Life Member - esarby (NSW) - Wednesday, Dec 14, 2011 at 07:59
Josh. with the Hillspeed you are not romoving the original speedo. it is a GPS unit that gives you the correct speed and you set it to the speed limit with warning Lights or sound if you exceed the limit. You can also see if your original Speedo is out of sync.
FollowupID: 747325
Follow Up By: Member - Josh- Wednesday, Dec 14, 2011 at 08:04
The origanal poster asked about changing his speedo, I was just pointing out the legal requirements. Don't think I'll bother next time.
Josh
FollowupID: 747326
Follow Up By: Life Member - esarby (NSW) - Wednesday, Dec 14, 2011 at 08:15
Sorry Josh, I know it it early in the day but I think I read it right.
thanks
Put means add not change. It is a stand alone unit, I put on the dash.
FollowupID: 747327
Follow Up By: Life Member - esarby (NSW) - Wednesday, Dec 14, 2011 at 11:53
Image Could Not Be Found
This GPS speedometer sits on your dash plug in or permanant wired.
FollowupID: 747345
Follow Up By: julian w1 - Saturday, Dec 17, 2011 at 14:13
thanks guy i see both ur points but i was thinking of replacing the whole thing the origanal odmeter doesnt work and i was thinking of putting in a system called dash comand which does the whole lot just something a bit more up to date any one know anything bout dash comand i see some things on youtube
FollowupID: 747580
Follow Up By: julian w1 - Saturday, Dec 17, 2011 at 14:19
what i really need to know bout is the sending units the seed sending unit from the gearbox is a cable but can i convert it to a electical unit once i know that i can figer out all the rest oil pressure temp ect
FollowupID: 747582
Follow Up By: Member - Josh- Saturday, Dec 17, 2011 at 19:56
Julian, It may be worth while checking what the regs are for changing the actual Speedo, If you ever decide to sell the vehicle it may cause problems if not done right. A little research now might save headaches later.
Josh
FollowupID: 747598
Reply By: Time - Wednesday, Dec 14, 2011 at 10:38
Have a look here.
Lots of good options including this comprehensive set up for $219
AnswerID: 472502
Reply By: Big Woody - Saturday, Dec 17, 2011 at 17:19
Hi Julian,
I have recently put a classic style digital speedo in my old F100.
You will need to buy a pulse generator to put into the speedo drive on your gearbox.
You should be able to get a pulse generator to suit the Toyota box.
You may also need to make a custom dash pod as from memory your original speedo is a funny shape. I made my dash face out of alloy chequerplate and it looks pretty nice.
Their will be about 4 or 5 wires to connect including 2 from the pulse generator, a power feed and a feed from your dash light circuit so it lights up at night.
My original speedo was almost 15km/h out but an advantage of the digital speedo is it can calibrated to match your gearing and tyre size. I have 36" tyres.
It is good to have a speedo that reads correctly now.
Brett
AnswerID: 472746
