wiring up touch screen
Submitted: Wednesday, Dec 14, 2011 at 10:47
ThreadID: 90637 Views:2759 Replies:4 FollowUps:3
Hi All : could use some help with this touch screen wiring .used with pc / gps / reverce camera .
what are they for... the small blue wire & the red av connection ? bottom of picture
top red is + & black is - , black connection 2nd power option .
2 yellows video ...reverse camera I think ?
I don't follow the wire diagram in top pic .
Image Could Not Be Found[fi]/Image Could Not Be Found
7'' touch screen monitor , vga ,usb input s video rgb, ntsc,/pal
cheers nick
Reply By: Member - Craig F (WA) - Wednesday, Dec 14, 2011 at 11:40
What are you trying to conect it to?
AnswerID: 472504
Follow Up By: Member - nick b - Wednesday, Dec 14, 2011 at 17:45
thanks Craig :its connected to laptop & hand held gps via a vga cable & usb missing from photo, with soft ware to match
cheers nick
FollowupID: 747364
Reply By: Member - Chris & Debbie (QLD) - Wednesday, Dec 14, 2011 at 12:31
Hi Nick
Been a while since I fitted mine but I would say the purple is for the hand brake connection so that the screen will not work unless the hand brake is on. You can usually just connect it to earth. The red RCA, again most likely is sound output to the stereo, would not worry about that one.
Not really positive info but may help
Chris.
AnswerID: 472508
Reply By: Member - Phil G (SA) - Wednesday, Dec 14, 2011 at 13:59
Red is usually hooked to the accessory power, so the screen switches off when you leave the car.
Black is neg.
The two yellows are the two RCA connectors for video input (usually reversing camera) and the second one is a spare that can be used for a second camera or other screen input (eg DVD). Do not use this for the computer input as the picture quality won't be good. the black female plug might be for power to the reversing camera.
VGA input is the best one to use for your computer input (mapping). It will give you the clearest picture. I can't see it in your photo, but expect you have a VGA lead that connects directly to the port on your monitor.
The USB can be left alone if you are not using the touch screen. If you want to use the touch screen, then you need to load the included software onto your computer.
You may need to purchase longer VGA, video and USB leads depending on where you're planning on storing the pc.
AnswerID: 472520
Follow Up By: Member - Phil G (SA) - Wednesday, Dec 14, 2011 at 14:22
Small blue wire might be the one that goes to the reversing light circuit so the camera switch on automatically when reverse is selected. And the Red RCA connector is probably sound input.
Your leads don't seem to match your diagram. I assume its the lead that plugs into the screen. And normally the two yellow and one red inputs are female not male, so it looks a little odd.
I've got a very similar screen at home and will check my instructions when I get home tonight or tomorrow.
FollowupID: 747354
Reply By: Member - nick b - Wednesday, Dec 14, 2011 at 18:10
Thanks for your replys , missing from the photo is the vga & usb cables ,
7'' touch screen monitor , vga ,usb input s video rgb, ntsc,/pal ...no name monitor with very poor instructions ,
The camera that I'm getting is also male end connection ,I guess I will need something to connect them ?
The touch & screen are all work after a lot of running around from computer shop & back to supplier ......Just need to work out the wiring !!!!
cheers nick
AnswerID: 472532
Follow Up By: Member - nick b - Saturday, Dec 17, 2011 at 11:41
For the record the small blue wire is a memory type like in a stereo continuous positive + from the battery .
If not connected the moitor still works but needs to be turn off & on when power is on for the screen to display .
reards Nick
FollowupID: 747572
