Saturday, Dec 17, 2011 at 17:49
Hi wombat, and as has been pointed out by both Captain and JohnR, the biggest single issue with a dual battery system, is the cable size.
If you don’t have the correct sized cable fitted, then you are starting from behind.
With correct size cable fitted, you then have a number of options.
Captain raised another potential problem that a number of late model Toyota 4x4s have, and this is their low operating voltage.
When you start a Toyota, the voltage is initially 14+v for ten minutes and then is drops back to 13.2v or less.
This is NOT a temperature controlled operation. You can drive for hours, pull up for
fuel, and ten minutes after stopping, with a hot motor, start the motor and the voltage rises over 14v and stays there ten minutes and then again, drops back to 13.2v
A number of European vehicles also have similar but more complex versions of this low operating voltage
While a DC/DC device can resolve this problem for a single battery set up, but because the Toyota system is just a simple timed controlled voltage drop, there is a much cheaper alternative and that is to fit an Alternator Voltage Booster.
This looks like and is a replacement for the ECU’s fuse but it tricks the Toyota’s ECU into thinking the voltage is lower than it is, so ECU cause the regulator to increase the alternator’s voltage to rise up by 0.6 to 0.7v
With a Alternator Voltage Booster fitted, you can now charge ALL your batteries at a higher, more efficient voltage.
The E-mail address is to the guy who developed and manufactures these Alternator Voltage Booster, I might add, they are made right here in Australia.
leigh@hkbelect.com
With decent cable and suitable operating voltages, there is another way to shorten your battery recharging time. If you have the room, fit an additional auxiliary battery.
This may sound strange but an alternator can charge two ( or more ) batteries in nearly the same time it takes to charge one.
Where the advantage comes in is that DC/DC devices will take the same time to replace the same amount of energy use. So if you have one battery and you use say 80 amperes of a 100Ah battery, taking it down to 20% SoC and it takes say 5 hours to replace the use energy using a 20 amp DC/DC device, and it takes an alternator say 5 to 6 hours driving time to get the batteries up over 90 to 95%.
Now if you have two 100Ah batteries and use the same amount of energy, the batteries will only be down to 60% but it will still take the DC/DC device the same amount of driving time but because an alternator can charge two batteries in near the same time it takes to charge one, and because the two batteries are only down to 60% SoC, an alternator can charge them back over 95% in 3 to 4 hours.
But far more important is the fact that an alternator will replace the bulk of the used capacity in the first 1 to an hour and 1/2, where as the DC/DC device will take at least 3+ hours to have the batteries up to the same charge level.
There are other advantages to adding an additional auxiliary battery but this shows there is more than one way to sink a cat.
747595
