Engine swap
Submitted: Friday, Dec 16, 2011 at 14:27
Scott H3
Hi, I have a 1988 hilux 2.4 D engine , will it fit into a 2000 toyota Surf auto,that has a blown motor.
Reply By: wizzer73 - Friday, Dec 16, 2011 at 15:51
Not sure but ask that question on the toyota surf
forum. They will know.
Isn't the 2000 surf a 3litre? Same as old prado motor? I think you will have problems bolting up to the auto and other electronics.
toyota surf forum
wizzer
472687
Reply By: Life Member - esarby (NSW) - Friday, Dec 16, 2011 at 16:05
Scott. I don't know where you are but you could give Jason at Total Care 4x4 at Seven
Hill NSW a call on 02 98389779. He did a similar job on "Toni"
472689
Reply By: Timla - Monday, Dec 19, 2011 at 13:26
You might want to check, but I'm 95% sure that you can't put an older engine into a new vehicle unless it meets certain EPA levels...
Or some such jargon...
472896
Follow Up By: Scott H3 - Monday, Dec 19, 2011 at 17:45
Hi all , thanks for the replys . I have decided to change tact may look at a recon motor ,so I can bolt it stait in without the headaches. thanks...
747718
