How to reapir water bladder
Submitted: Saturday, Dec 17, 2011 at 16:06
ThreadID: 90688 Views:1967 Replies:3 FollowUps:3
Can anyone give me any suggestions of how best to repair a red Opposite Lock 40 litre water bladder? It has sprung a leak on the seam of the black insert.
Reply By: Notso - Saturday, Dec 17, 2011 at 16:31
A Vinyl welder may do it.
Awning and Blind makers have em.
AnswerID: 472739
Follow Up By: Adey - Saturday, Dec 17, 2011 at 16:47
Thanks for prompt response. I will give them a try.
FollowupID: 747590
Reply By: Mick O - Saturday, Dec 17, 2011 at 16:45
Did Opposite Lock offer any wisdom? They may be able to return it to the manufacturer for repairs.
Cheers Mick
AnswerID: 472741
Follow Up By: Adey - Saturday, Dec 17, 2011 at 16:46
Waiting on an email from them but I have it for 10 years so can't complain about the service. I'll see what they say.
FollowupID: 747589
Reply By: dieseltojo - Saturday, Dec 17, 2011 at 21:16
Hi Adey,
Get a couple of bits of ss say 25 x 50 mm. On one bit weld two 4 mm studs 20 mm long. drill two holes in the other plate to suite the studs.
Cut two bits of rubber to fit the studs.
Put one rubber gasket over the studs , slit the bladder enough to fit the plate internally. You should be able to hold the plate ok from outside the bladder. Put some silicone on the bits, put on the external gasket and plate and bolt together.
That's how I fixed many a water bed in the good old days.
AnswerID: 472759
Follow Up By: Adey - Sunday, Dec 18, 2011 at 12:48
Thanks - I will give that a crack.
FollowupID: 747632
