Installation of cramer ce99/41 (Dometic)gas stove
Submitted: Sunday, Dec 18, 2011 at 17:26
ThreadID: 90710 Views:4823 Replies:3 FollowUps:0
Have purchased the above 2 burner gas stove to replace one in my hard floor camper,just connected the original gas hose all ok ,i cant get the ignighter to strike,does it need 12v power supply,there are no obvious connections.
Any help greatly appreciated,merry christmas to all.
Reply By: LeighW - Monday, Dec 19, 2011 at 09:34
More detail as to the model number is required.
If the install instructions don't mention a 12V or 240V connection then it won't
have one.
I suggest if you don't have the install instructions you check out the dometic website as they will be available there.
LeighW
AnswerID: 472879
Reply By: Member - Captain (WA) - Monday, Dec 19, 2011 at 10:28
My one has a AA battery inside the igniter. Try unscrewing the pushbutton and there is a place for the battery there.
Captain
AnswerID: 472884
Reply By: pepper2 - Tuesday, Dec 20, 2011 at 09:23
Thankyou both for your replies it turned out that i mounted the stove too close to the metal plate below and it was earthing out packed it up with half inch of rubber all ok.
AnswerID: 472966
