zd 30 won't start
Submitted: Sunday, Dec 18, 2011 at 23:56
ThreadID: 90719 Views:12816 Replies:10 FollowUps:1
any body had trouble starting zd 30 in patrol? mine cranks over but won,t fire have checked glow plugs and pumped fuel pump till tight and just winds over & over but won,t fire. can get it to fire by spraying aero start in to intake ,its like something is not telling the injector pump to do its job. has been starting and then stopping in the mornings and have to hand pump it to get it going again but that not working either now.help?????????
Reply By: Member - Stuart P (WA) - Monday, Dec 19, 2011 at 00:40
do you have an air blockage to the fuel pump(air on top of the fuel filter) make sure the hand primer is hard
the battery check its state of charge
AnswerID: 472857
Reply By: Mick O - Monday, Dec 19, 2011 at 07:39
Might seem a bit strange but are you using the key you would normally use and not a spare? Does that key have the thick black end piece with the immobiliser switch in it. Have you dropped your keys in dirt, dust, mud or water recently? Notoriously fickle if dirty.
You might do well to pop over and ask the question at the Patrol4x4 forum also.
Cheers Mick
AnswerID: 472863
Reply By: Patrol22 - Monday, Dec 19, 2011 at 07:50
Two good responses above....both could be the source of your problem but before going off to Mr Nissan to get the key checked make sure your fuel system is primed....keep pumping that black knob atop the fuel filter until you can't compress it anymore.
AnswerID: 472864
Reply By: Member - Bucky - Monday, Dec 19, 2011 at 09:10
Blocked filter ?
Filter ?.... Even new ones can be faulty !!!
Small hole in fuel line ?
Cracked or unsealed fuel filter/primer mount ?
Crook fuel ?
Are there any inline filters, as with the mighty 4.2, that flattened my Patrol for 2 days, til it was located and cleaned ?
Get down to a diesel specialist, not necessarily a Nissan Dealer, as they charge way too much
Cheers Bucky
AnswerID: 472871
Reply By: Greenant - Monday, Dec 19, 2011 at 09:29
Sorry to say this but I believe your problem is with the electronics in the injector pump not cheap to have fixed as I had a similar problem and after lot of so called experts having a go at it and having mine towed from place to place this was the fault
Greenant
AnswerID: 472877
Reply By: patto - Monday, Dec 19, 2011 at 10:55
We had the same problem with one of our works vehicles up by Lake Eyre every thing seemed to work but it would not start. Work arranged for the mechanic from Copley to come and check it out and when he arrived on site he removed the panel under the steering column and pulled out the relays (there is 4 of them from memory) one at a time and then replaced them and the vehicle started. He reckons it is a very common fault with Nissans especially if they are used in a dusty envioronment
AnswerID: 472887
Reply By: Member - Bentaxle - Monday, Dec 19, 2011 at 22:57
Beegee, I've just been down the same road and its expensive around $3500. The problem is more than likely the contol unit on the injector pump. Another cause of the problem is a faulty sensor on the injector pump. You don't say where you are based, but if in Perth the only place to get it fixed is United Fuel Injector Systems Gt Eastern H'way, Redcliff
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 472942
Reply By: 120scruiser (NSW) - Tuesday, Dec 20, 2011 at 21:35
Check the battery
Some times the battery has enough power to crank the engine but not enough to run the electronics. I had one in my workshop like this. Put a new battery in it and it fired.
Scott
AnswerID: 473016
Reply By: Beegee - Tuesday, Dec 20, 2011 at 22:38
Thanks everyone,have a lot of things to try. will try to let you know how it went Merry Xmas
AnswerID: 473026
Follow Up By: Beegee - Wednesday, Dec 21, 2011 at 20:14
Just another question . does anybody know how to over ride the NATS on a patrol zd30 2000 model auto so i can rule that one out? any help much appreciated. coming up with codes 0703 ,1003 (which i understand because EGR is blocked off) 1004 and 1401 .checked wiring and plug in back of pump for continuation and all ok. when i checked for power to the pump there is only one wire that is live when ign. on is that right ? thanx Beegee.
FollowupID: 747877
Reply By: PeterInSa - Thursday, Dec 22, 2011 at 11:51
BG,
Regardless of the outcome of your current problem I would join the Patrol Forum and probably the Outer Limits 4x4 Forum as well.
A wealth of experience and guys willing to help.
AnswerID: 473082
