Tyre sizes?
Hi All, did a quick search of Tyres but could not find what I was after.
I have always run 275x75x16 on my Jack, now I have just bought a Triton ute with 31x10.5x15 WTF? How do these compair size wise?
I am up for new tyres before easter and would like to give the appearance I know what I'm talking about;-)
Bet theres an easy way to do the comparison, but I don't know what it is.
Ian
Reply By: Mudripper - Monday, Dec 19, 2011 at 11:22
Hi, try the tyre size calculator on this website:
http://www.exploroz.com/Vehicle/Tyres/SizeCalc.aspx (couldn't use the Insert Link feature for some reason).
Cheers.
AnswerID: 472889
Follow Up By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 11:25
Thanks Mud, excellent, answers my question spot on
FollowupID: 747693
Reply By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 11:40
Ok, additional question,
Would it be better to go to 32" on the 15" rims or get some new 16" rims and go 275 x 75?
Happy with the current rims but as I'm getting new tyres would like to increase the diameter, seem to have plent of clearance, suspect the 2.8lt TD would not suffer much from the increased circumference.
AnswerID: 472891
Follow Up By: Trev6 - Monday, Dec 19, 2011 at 18:31
I tired bigger wheel on my 3L hilux just to see how it would go , I went from a 30x9.5 x15 to a 7.50x16 and it died just at the sight of the hill coming, but in saying that the 2.8 was a much better motor than the 3L pile of junk so you may be ok with yours.
The other thing I can think of is going higher in the side wall is it probably won't corner so well as it will give more "roll" in the tyres but then it all depends on where and how you want to drive it
Just my thoughs
Trevor
FollowupID: 747727
Follow Up By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 18:55
thanks Trev, may stick to the same size as I have
FollowupID: 747729
Reply By: Member - Josh- Monday, Dec 19, 2011 at 12:01
One thing to be aware of with different tyre sizes is the weight rating. I had 285/75/R16 Mickey thompson tyres on my 80 series. 33" Mickey Thompson tyres had a lower weight rating and were not legal for my cruiser. Worth keeping in mind.
Josh
AnswerID: 472893
Follow Up By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 12:07
Thanks Josh, did not give that a thought. Assumed that they would be capable of handling the weight of a loaded vehicle.
Rgds
FollowupID: 747695
Follow Up By: Lex M - Monday, Dec 19, 2011 at 12:32
Not to mention the legality of it all. Even the 31's may not be legal, they're not in my state.
FollowupID: 747698
Follow Up By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 12:42
Mmmmm, did not know there were illegal in some states, like to see that one go to court.
FollowupID: 747699
Follow Up By: Lex M - Monday, Dec 19, 2011 at 17:24
If you're REGISTERED in Queensland, this is the regulation that applies. Don' t know about other states.
"The rim diameter may be varied from the standard size
but the overall diameter of the tyre must not vary by
more than +15mm or -26mm."
FollowupID: 747716
Follow Up By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 18:02
Hi Lex, now I understand, they may be big, not that they are 31".
FollowupID: 747723
Reply By: Penchy - Monday, Dec 19, 2011 at 12:28
Also speedo calibration may go out. Increase the tyre diameter and you may be up for a different pinion for the speedo cable. Or use your GPS as the speedo, up to you.
AnswerID: 472895
Follow Up By: Member - Noldi (WA) - Monday, Dec 19, 2011 at 12:45
Hi Penchy, yes the larger tyres in the Jack put the speedo out by 10% checked by several GPS's in convoy. easy once you got used to it, a bugger when you were doing night navigations though, trying to work out 13.3 km less 10%
FollowupID: 747700
Follow Up By: Nomadic Navara - Monday, Dec 19, 2011 at 19:19
The following is taken from Vehicle Standard (Australian Design Rule 18/03 – Instrumentation) 2006:
5.3. The speed indicated shall not be less than the true speed of the vehicle. At the
test speeds specified in paragraph 5.2.5. above, there shall be the following
relationship between the speed displayed (V1) and the true speed (V).
0 = (V1 - V2) = 0.1 V2 + 4 km/h
If you put tyres on your vehicle that put your speedo out of that range you should change the calibration of it to keep your vehicle roadworthy.
FollowupID: 747731
Follow Up By: Nomadic Navara - Monday, Dec 19, 2011 at 19:27
I was able to copy the correct symbols into the reply correctly but they were changed by the forum after I hit submit.
Those = symbols were supposed to be a combination of the < symbol and the = symbol meaning equal or less than. In other words 0 must be equal to or less than V1 - V2 (etc)
FollowupID: 747733
Follow Up By: Nomadic Navara - Monday, Dec 19, 2011 at 19:30
Also the line "relationship between the speed displayed (V1) and the true speed (V)." should read:
relationship between the speed displayed (V1) and the true speed (V2).
FollowupID: 747736
Follow Up By: Member - Noldi (WA) - Tuesday, Dec 20, 2011 at 09:43
Geeze Pete I hope they don't check my bus, at 80kph I'm actually doing 100.
Note your sig block, I did 15 yrs in the services as a Tech
FollowupID: 747770
