help from triton owners - triton leaking water
Submitted: Monday, Dec 19, 2011 at 18:44
ThreadID: 90733 Views:7818 Replies:1 FollowUps:5
Help! Our 2005 triton has developed a water leak. The last 3 times its rained heavy we've had water on the front passenger side floor. This time was quite a bit. We've felt up under the dash and it all seems dry. I suspect it may be coming in thru the plenum. Anyone else experienced this problem?
Reply By: gbc - Monday, Dec 19, 2011 at 19:21
Has the car had its windscreen replaced? First place I'd look.
AnswerID: 472921
Follow Up By: louie the fly - Monday, Dec 19, 2011 at 19:27
Apparently not. We only had it 3 months. Bought from original owner. All service docs and receipts for everything are there. Nothing that points to a screen being replaced. Gonna chech the vent drain.
FollowupID: 747734
Follow Up By: louie the fly - Monday, Dec 19, 2011 at 19:49
Well I just took the vent cover off and poured some water in the vent area and found something bizarre. The RHS of the vent is draining freely. It has a huge drain that runs out behind the driver side front guard, but it looks like the water running off the left side of the windscreen drains into the engine bay and runsdown the UHF coax. Then, where it and the wiring loom go through the firewall grommet, the water apears to be traveling down the wiring and into the cabin. Will seal it up with some silicon and see what happens from there.
FollowupID: 747740
Follow Up By: Fred G NSW - Monday, Dec 19, 2011 at 20:23
Louie my 01 MK has similar drainage points on BOTH sides. Occasionally leaves and other crap get stuck in there, and I open both doors, stick the hose down the back of the guard, and am constantly amazed at the amount of crap that drains out the bottom. Sounds like your passenger side is clogged. If you lift the bonnet, also flush from there, at the top, both sides of the windscreen, as that is where a lot of muck gets stuck, letting the water drain off in other directions.
Good Luck. I do that regularly, and no problems.
Fred
FollowupID: 747744
Follow Up By: louie the fly - Monday, Dec 19, 2011 at 20:59
Thanks for the replies. Checked the drains and they all clear. After copious amounts of polyurethane sealant on the cables and hole in the grommet, and making a small diversion drain, and getting it all over my handhands, shirt and shorts, I think its fixed. Have poured a few buckets of water over it and it seems OK. Turns out it was wet up higher where the cables run down behind the soundproofing.
FollowupID: 747747
Follow Up By: Member Andys Adventures - Monday, Dec 19, 2011 at 22:04
Hi louie the fly, Instead of silicon use expander foam, had the same problem when up the Cape last year. You can trim off the excess when it dries and is easy to remove if you need to add or replace a cable.
Andy
FollowupID: 747754
