pajero 3.5 spark plugs
Submitted: Tuesday, Dec 20, 2011 at 19:18
zacc
Hi all i would like to know if any one has used the Champion double platinum RC10PYP4 in there petrol pajeros ? if so how did they perform . I ask because i have a set but the do not have the pin electrode like the ngk . It also runs on gas.
Reply By: Roughasguts - Tuesday, Dec 20, 2011 at 19:39
Your lucky I can't even get
mine out!!
The carbon build up must have clogged the threads in the combustion chamber.
473008
Follow Up By: zacc - Tuesday, Dec 20, 2011 at 20:55
Try running the engine till it is hot then get them out , you will have to take every thing off when hot , bit of a pain but that will help.
747825
Follow Up By: Roughasguts - Wednesday, Dec 21, 2011 at 12:19
Cheers I''l have to try that it's a constant very tight pressure on them to undoo. Don't want to risk it when there that tight.
747863
Follow Up By: Fred G NSW - Thursday, Dec 22, 2011 at 09:13
Roughasguts, mate, can you let us know how you eventually get on with that problem. It's got my attention.
747892
Follow Up By: Shaker - Thursday, Dec 22, 2011 at 09:44
Make sure that when you loosen them that you ease them each way a little as you remove them, otherwise you will probably bring the thread out with them.
747895
Follow Up By: Roughasguts - Thursday, Dec 22, 2011 at 10:13
Yeah I tried that Shaker as you do to loosen bolts so as not to break them tighten them up loosen with plenty of lube Etc.
But it was just as tight both ways which is the real concern as it might be comming out but cross threading on the way back in.
Unfortunately the jobs on the back burner for the moment so many other things to take care of for the moment. The car still runs fine but it's the valve guide seals I need to replace there a tad smoky on start up.
Cheers.
747899
Reply By: 120scruiser (NSW) - Tuesday, Dec 20, 2011 at 21:18
There is a product made by Wurth called "Rost Off"
Grab a can of this and remove your spark plug leads and spray it down the tubes. Leave it a while and give it another spray. In about a week give them a try. You might have to unscrew them a bit, give them a spray, screw it back in then out and continue to repeat this till the rost off gets down into the thread.
They should come out.
Scott
473014
Follow Up By: Roughasguts - Wednesday, Dec 21, 2011 at 12:20
Thank's Scott.
747864
Follow Up By: Shaker - Thursday, Dec 22, 2011 at 09:43
Rost Off is one of the best products for any stuck, seized or rusted objects.
747894
Follow Up By: Roughasguts - Thursday, Dec 22, 2011 at 10:18
Never seen it before! ..where can I get it???
Cheers.
747900
Follow Up By: Shaker - Thursday, Dec 22, 2011 at 19:47
I am fairly sure Repco has it.
747931
Follow Up By: Roughasguts - Friday, Dec 23, 2011 at 05:17
Cool!.... Thanks Shaker.
747948
Reply By: The Bantam - Wednesday, Dec 21, 2011 at 10:20
Serioulsy..I swore off champion spark plugs years ago, the quality simply isn't there in my opinion.
I will only use NGK or Nipondenso.....I wont even put a champion in my mower.
As far as getting spark plugs stuck...these days I put neverseeze on just about everything including spark plugs and glow plugs.
473044
Follow Up By: Roughasguts - Wednesday, Dec 21, 2011 at 12:22
Yup for sure I'll be using never seeze from now on.
Never had this in me life happen on spark plugs.
Cheers.
747865
Follow Up By: Shaker - Thursday, Dec 22, 2011 at 09:46
Historically Champion plugs have been very hard on aluminium cylinder heads as they don't have a rolled thread.
I used to race Formula Vees & Champion plugs were taboo!
747896
