4 x 2 towing
Submitted: Tuesday, Dec 20, 2011 at 20:55
Ann F
Hi all, I am thinking about towing with a toyota Extra cab 4 x 2 but am a little unsure of the capacity of the vehicle.
Reply By: Member - colin J (VIC) - Tuesday, Dec 20, 2011 at 21:52
Hi Ann F,
Finding out the towing capacity of the vehicle should be pretty easy but what are you towing, what weight is the van, trailer etc and what is it's load or hitch weight that will be transfered to the vehicle? What year was the car made. Has there been any modifications to the
suspension, and where are you intending to tow. Does the setup require electric brakes etc.
A fair bit more info is required before anyone can give you any meaningful advice
Col.
473019
Follow Up By: Ann F - Tuesday, Dec 20, 2011 at 21:59
thanks,I'm looking at a new 2011 extra cab. I have a coromal 16foot pop top 2010.
747828
Follow Up By: Ann F - Tuesday, Dec 20, 2011 at 22:01
I'm actually looking to find someone who has had a 4 x 2 and find out how it has performed for them.
747830
Follow Up By: dazren - Tuesday, Dec 20, 2011 at 22:22
Hello ANN i have posted below ?? re my 2WD drive Colarado, If you are towing the Coramal poptop the Toyota will walk it in, you do not say if you are going for the Diesel or petrol motor, [ personal choice ] and a whole new debate ??
diesel will pull it very easily, but those toyota 4 ltr petrol motors are also pretty good and would handle a 16' poptop with ease !
I went 2 wd this time as i do not do any hard 4wd tracks, only dirt roads and along the river tracks, as long as you have ground clearance 2 wd is all you need
My last vehicle was a 4WD and in 5 years i think i only engaged 4wd twice
747832
Follow Up By: Ann F - Wednesday, Dec 21, 2011 at 20:37
thanks for the info
747880
Reply By: Member - Boo Boo (NSW) - Tuesday, Dec 20, 2011 at 21:53
Ann
Generally its towing capacity is 2250kg
473020
Follow Up By: Ann F - Tuesday, Dec 20, 2011 at 22:00
thanks
747829
Reply By: dazren - Tuesday, Dec 20, 2011 at 22:10
I Drive a Holden Colarado dual/cab 2 WD Ute tow capacity 2500 kg, Ball 250kg
I tow a Lotus 19' Full ensuite van All up tow weight 2340 kgs It tows the van
well, could do with a little more power on Big hills but it does the job quite
Mine is factory fitted Duel/
Fuel, I get 15 L/per 100 k around town and when towing I average 25 ltrs per 100 k
So if the toyota 2WD is your vehicle of choice go for it, but make sure your choice of van is within it's Towing limits Rgs dazren
473024
Follow Up By: Ann F - Tuesday, Dec 20, 2011 at 22:21
Thanks for that.
747831
Follow Up By: dazren - Tuesday, Dec 20, 2011 at 22:30
Ann if i tow on Petrol I get around 19 litres per 100k, but my van is a lot heavier than yours and if you are going the petrol motor, it is bigger than
mine and has more torque, so your consumption shold be less than that. dazren
747833
Reply By: ozjohn0 - Wednesday, Dec 21, 2011 at 13:48
Hilux 2WD & 4WD have the same tow capacity.
From 2005 onwards it's 1200Kg with the light weight tow bar and 2250Kg with the heavy duty tow bar.
Toyota also recommend that a WDH be used.
Check the vehicle handbook for further infiormation.
Ozjohn.
473052
thanks for the time and info
747881
