Aircon pipe on Patrol '04 3.0l and 4.2l the same?
Submitted: Wednesday, Dec 21, 2011 at 11:03
ThreadID: 90768 Views:2542 Replies:2 FollowUps:3
Hi Everyone,
My aircon pipe that runs along the firewall at the back of the engine has rubbed a hole through it. Can anyone tell me if one from the 4.2 Ute is the same?
Thanks,
Leroy
Reply By: Member - Tony H (touring oz) - Wednesday, Dec 21, 2011 at 11:14
Hi Leroy,
There two pipes running across the firewall, one is called the liquid line, (which is smaller in diameter compared to the other line that is called the suction line.
The liquid lines should be the same, but the suction lines will be different. Make sure you fit new O rings to the pipe fittings.
Hope this helps
AnswerID: 473049
Follow Up By: Leroy - Wednesday, Dec 21, 2011 at 11:22
Thanks for the reply. Which is the high pressure line?
Leroy
FollowupID: 747858
Follow Up By: Member - Tony H (touring oz) - Wednesday, Dec 21, 2011 at 11:58
The liquid line is the line that carries higher pressure when the system is operating.
At rest (system turned off) pressure equalises in both liquid & suction lines.
FollowupID: 747861
Follow Up By: Member - KozInOz - Thursday, Dec 22, 2011 at 01:15
The small one. Check out how aircon works at wiki
FollowupID: 747890
Reply By: Member - Rob D (NSW) - Wednesday, Dec 21, 2011 at 16:18
I had the same thing happen on my 4.2 Patrol about 5 years ago.
The guy I took it to had some sort of special welder which allowed him to repair the pipe, saving quite a few hundred dollars. Good luck.
If you relax at a faster pace you can get more relaxation in for a given time.
Regards Rob
AnswerID: 473056
