altering trailer GVM
Submitted: Saturday, Dec 24, 2011 at 12:28
ThreadID: 90815 Views:11572 Replies:7 FollowUps:7
Has anyone added brakes to an already reg. trailer and then got it re inspected to get the change in the GVM updated, is it possible to do?. I would like to do this to mine so I can legaly carry more weight above the 750kg limit (to around 1400-1500kg) but I am unsure as to what will be involved in the re- doing of the compliance plate figures.
The Trailer is a 7x4 off road with 7 leaf springs & 45mm axle , NSW rego.
Thanks, Trevor
Reply By: The Bantam - Saturday, Dec 24, 2011 at 14:10
There are ligitemate ways of doing this while the trailer is still registered, but the hoops and fiddle and the cost.
The physical change are relativly straight forward..as long as the frame is strong enough, replace axle & possibly springs adding a braking system.
It is easier to recompliance it and re register it as a home built trailer with a new VIN plate..oh yeh that is dodgy too.
If you are the type that plays by the letter of the rules, its simpler to sell the thing and buy/build a new one.
AnswerID: 473241
Reply By: blown4by - Saturday, Dec 24, 2011 at 23:08
Not sure about the NSW rules but in WA you would just need to install a brake kit and ensure the frame, suspension, axle, tyres, rims & safety chain are good for the GVM you want (up to 2000kg GTM unless you fit break-away brakes). IN WA you would stamp a new compliance plate with the upgraded Tare & ATM using the same VIN and hand the original compliance plate in to the DoT when you have the trailer re-assessed for the increased ATM to get the rego record updated.
Lots cheaper than a new trailer.
AnswerID: 473276
Reply By: Michael ( Moss Vale NSW) - Sunday, Dec 25, 2011 at 06:26
I think you would best take it to a blue slip inspection station to discuss the upgrade and confirm the new load rating if the brakes were to be installed. I assume the build of the trailer may be what governs the payload. Springs and axle are good for the load but the chassis would be part of the consideration for the extra load.. Your rego will go from $50 to $150 per year MIchael
AnswerID: 473279
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Dec 25, 2011 at 06:26
You will need to get a new compliance plate fitted... Michael
FollowupID: 748077
Reply By: Trev6 - Sunday, Dec 25, 2011 at 11:59
Thanks for the replys so far, I will have to look into it a bit more when people come back to work.
AnswerID: 473290
Follow Up By: Shaker - Sunday, Dec 25, 2011 at 23:42
Your suspension will have to rate at a minimum of 120% of the ATM.
FollowupID: 748121
Reply By: pop2jocem - Sunday, Dec 25, 2011 at 12:02
One item to look at in addition to chassis, springs and axle size is the tyre rating. It looks as if you are wanting to virtually double the payload and depending what tyres it has you may be required to up grade.
As others have said it may be easier to de-license or let the existing run out, do your upgrades and present it for inspection with a clean slate so to speak.
Pop
AnswerID: 473291
Reply By: Member - Frank P (NSW) - Sunday, Dec 25, 2011 at 12:26
Hi Trev,
I did exactly what you propose and it was easy.
The camper trailer chassis was already substantial but it had no brakes and just slipper springs.
I had the drawbar modified to come back to the front spring hangers, changed the springs to shackle front and rear and fitted a new braked axle. It already had light truck tyres, so load rating fr the tyres was OK.
I had a blue slip inspection done - he looked at all the work that had been done and also at the tyres and re-rated it at 1240kg. Rgo went from $23.00 to $50.00.
Frank
AnswerID: 473294
Follow Up By: Member - Frank P (NSW) - Sunday, Dec 25, 2011 at 13:27
I should have said that those rego prices were of the time - about 4 years ago.
Frank
FollowupID: 748090
Follow Up By: Michael ( Moss Vale NSW) - Sunday, Dec 25, 2011 at 18:41
Frank, Anything with brakes is $150 now in NSW.. Michael
FollowupID: 748104
Reply By: Trev6 - Sunday, Dec 25, 2011 at 13:09
Thanks Pop & Frank, The trailer is up to scratch build wise it's just missing the brakes so it all should work
Trevor
AnswerID: 473298
Follow Up By: Inflataduck - Sunday, Dec 25, 2011 at 17:50
Trev your in nsw there's many ways of doing it legal as others have said get it blue slipped or RTA put out a list of approved engineers & they can inspect & write report & No need for blue slip i often do this on boat trailers as its cheaper as many insurerers demand it, but if you no the manufacturer check if your model comes in a up rated model & if so they may be happy to replated it after inspecting it you will still have to get it re-blue slipped but your insurer will be happy as well
good luck
FollowupID: 748101
Follow Up By: Inflataduck - Sunday, Dec 25, 2011 at 17:55
I meant to say only cheaper because to get it blue slipped & then have to pay for an engineers report for the insurance company means you paid for a blue slip for nothing
FollowupID: 748103
Follow Up By: Nomadic Navara - Sunday, Dec 25, 2011 at 21:18
The guide document for building small trailers is VSB-01 June 2009
I don't know about this no blue slip required with an engineers report. When I upgraded the weights of my van I was sent for a blue slip after I received my engineers report. You will find a list of engineering signatories in VSI-15
FollowupID: 748113
