replacing wheel bearings toyota troopie 1995
Submitted: Tuesday, Dec 27, 2011 at 11:15
ThreadID: 90848 Views:4876 Replies:7 FollowUps:1
Hi all members, I am wanting to replace front and rear wheel bearings in my 1995 toyota troopie and would appriciate feedback on ins and outs of doing so. Would like to know if it is worth doing myself as i would like to know/ gain the experience if emergencies may arise while out bush.
Reply By: Lyle87 - Tuesday, Dec 27, 2011 at 11:43
Hey mark
just read the book it will tell you everything u need to know. yu may want to go get a socket. you can get a universal one for 55-60mm just for that job. make sure u pack the bearings well to.\
AnswerID: 473398
Reply By: Mr Pointyhead - Tuesday, Dec 27, 2011 at 12:27
I have seen some youtube videos on how to do it as well. Also there is a lot of information on various web sites with tips and tricks on how to do it including tools required.
Google is your friend to find the info :)
AnswerID: 473401
Reply By: Hairs & Fysh - Tuesday, Dec 27, 2011 at 12:41
Hi Mark,
I purchased a Nut Socket off eBay, but from another seller.
54mm 3/8" Wheel Bearing Hub Nut Socket Toyota
54mm 3/8" Wheel Bearing Hub Nut Socket Toyota Hilux 4x4
54mm Front Hub Nut Socket to suit 3/8 drive
Toyota Landcruiser - 40 series, 60 series, 70 75 series, 80 series, 100, 105 series
Bought the bearing kit from my local Auto Parts guy,
A handy bit of kit.,
Cheap as chips.
AnswerID: 473402
Reply By: mark p7 - Tuesday, Dec 27, 2011 at 12:53
Hi All,
Thanks for your replies and handy tips. I will follow up with sockets and tips off the internet. Lyle did you mean the manual for the Troopy?
Thanks again.
AnswerID: 473403
Follow Up By: Bigfish - Tuesday, Dec 27, 2011 at 15:44
Its very easy plus 2 benefits..1. You know how to inspect/fix if yoou have gremlins in the future. 2. You can be confident that the job is done correctly/
Plus..money saved. Go for it.
FollowupID: 748234
Reply By: Member - Alastair D (NSW) - Wednesday, Dec 28, 2011 at 08:09
Mark,
Further to the advice you have been given.
Use either genuine Toyota bearing kits or Japanese made quality bearings. Some of the el cheapo kits around have Chinese made bearings in them and they are not as reliable. Given the consequences of bearing failure on a trip it is just not worth saving a few $.
After you have done say 1000 km following the replacement check each wheel for play. The fronts are just a matter of jacking up etc. For the rears you need to check the manual.
Carrying pre packed bearings in a zip lock plastic bag makes field replacement much easier.
AnswerID: 473456
Reply By: Bob Y. - Qld - Wednesday, Dec 28, 2011 at 12:53
Mark,
If you haven't done this before, one piece of advice I'd give is to "freeze" the cups of the bearings. Just chuck the cups into the freezer, as you get all the other stuff together. Then when you press or drive them into the hub, they go in a bit easier. Also, plenty of WD-40 as you press them in, helps too.
Bob.
AnswerID: 473476
Reply By: 158 - Wednesday, Dec 28, 2011 at 20:38
Mark
Try this web site http://www.youtube.com/watch?v=_3CI4mmEv6A
AnswerID: 473506
