Storing tyres for longer life ? myth or fact ?
Submitted: Wednesday, Dec 28, 2011 at 20:22
ThreadID: 90870 Views:4094 Replies:9 FollowUps:9
I remember a few of my 4x4 friends from Years ago would buy a few sets of tyres for there rigs then throw them in the shed for 1 - 2 years before using them on there rigs - there reason was they said they get almost double to life out of the tyres , once fitted as they had " cured" or hardened and wear was much slower
Is there any merrit in this or just an old waves tail ?
Reply By: pop2jocem - Wednesday, Dec 28, 2011 at 21:43
My 2 bobs worth, yep I always try to "let them cure" for at least a year before using them, and yes this comes from many years of doing the "fit and drive" and "store and drive". Tyres do cure or harden. It amuses me when I read stories about not using tyres more than 5 or 6 years old.
But hey opinions are like armpits.
Pop
AnswerID: 473516
Follow Up By: Dennis Ellery - Wednesday, Dec 28, 2011 at 23:37
5 or 6 year old tyres may be harder amd wear better but are prone to throwing a tread – now when that happens it should give you a lot more amusement.
FollowupID: 748369
Follow Up By: Member - Frank P (NSW) - Thursday, Dec 29, 2011 at 09:08
"It amuses me when I read stories about not using tyres more than 5 or 6 years old."
If you google "ageing of tyres" you'll find enough info from reputable sources to indicate that tyres over 5 to six years old are unsafe.
You may like to dice with Darwin, but when you do just make sure my family is not involved.
Frank
FollowupID: 748383
Follow Up By: fisho64 - Thursday, Dec 29, 2011 at 11:39
tyre life I believe is linked to UV exposure-sitting in a shed should negate that Id say?
FollowupID: 748392
Follow Up By: member - mazcan - Thursday, Dec 29, 2011 at 12:02
hi begaboy
tyres have a manufactures date on the side of them and according to that they are good for about 6yrs by what i have read and been told by the tyre dealers despite the small distance they may or may not have covered
thats irrelevant as far as the safety factor goes
yes they do harden with age and become less flexible and also loose they gripperbility as this happens
they ride harder and stake easyier but you can get quiet a long distance out of the hardened tyre at your on risk and to passengers and other road users until when one decides to blow out ???
i have kept some tyres too long and although they didnt blowout they became brittle with the tread disintergrating and cracking and also distortion in the casings making it impossible to balance them
in a nutshellit your dice
so with that said the ball is in your court you decide which is more important your lives and others or how far and how many k's you can get for what cost savings ??????
have a HNY
FollowupID: 748393
Follow Up By: member - mazcan - Thursday, Dec 29, 2011 at 12:08
hi as a matter of interest
about the only thing that hasn't got a use by date these days on them is a pair of jocks and thats because they are always used on a date !!
FollowupID: 748395
Reply By: get outmore - Wednesday, Dec 28, 2011 at 22:39
myth
if you want hard tyres just buy them. harder the tyre the less grip it will have
Tyre Ageing Mechanism
There are three main mechanisms of tyre ageing. The first involves rubber becoming more brittle. Sulphur is used to link rubber molecules together during vulcanisation with the application of heat and pressure, giving the rubber its useful elastic properties and strength. As the tyre absorbs energy in the form of light, heat or movement the tyre continues to vulcanise. This ongoing vulcanisation causes the rubber to become stiffer and more brittle.
The second mechanism of tyre ageing is oxidation involving oxygen and ozone from the air compromising the strength and elasticity of the rubber and the integrity of the rubber to steel bond. Basically heat and oxygen cause cross linking between polymer chains (causing the rubber to harden) and scission of polymer chains (leading to reduced elasticity).
Thirdly, breakdown of the rubber to steel-belt bond will occur due to water permeating through a tyre and bonding with the brass plate coating on steel belts. This causes the steel to rubber bond to weaken leading to reduced tyre strength and reduced heat resistance. If compressed air used for inflation is not completely dry, tyre strength will be affected over time. Even unused tyres will become more brittle, weaker and less elastic with exposure to water, air, heat and sunlight.
AnswerID: 473522
Reply By: howesy - Wednesday, Dec 28, 2011 at 23:18
from my experience with aged hardened tyres the more they harden the less grip in the wet and eventually you end up driving like miss daisy in the wet because they become almost dangerous. When driving on them as they harden I usually find they become ultra slippery around the 80-100K mark but if they are hard you can get serious milages if you rotate most i ever had was 140K out of Kumho ventures
AnswerID: 473523
Follow Up By: Member - onemore - Thursday, Dec 29, 2011 at 07:28
when my dad had a blow out recently the tyre bloke told dad although the tyres had not done many k's, and the vehicle was always garaged, what had in fact happened was that they had become old, and that tyres had a use by date.
(tyres were about four years old).
Solution: I will sell you you four new tyres, so this doesn't happen again.
FollowupID: 748377
Reply By: Fab72 - Thursday, Dec 29, 2011 at 09:08
Begaboy,
I inherited a 1993 Mitsi Lancer from my old man when he passed on. At the time, the car was 11 years old and had only travelled 18,000kms (mostly done by me when my car was off the road for various reasons).
Anyway...The car has now done 105,000kms, but the originals tyres weren't replaced until the 88,000km mark. Now these tyres weren't anything special and I sure as hell didn't drive the car like my old man used to either. So I guess there is merit in what you are saying.
HOWEVER.... the tyres would squeal like a pig going around corners in the dry, handled like a shopping trolley in the wet, became noisy and the tread did start to delaminate (even on the spare which had never seen the bitumen). They still had a fair bit of tread on them when I replaced them, but they were unsafe. Imagine causing a head-on after having a blow out at 100kmph.
MORAL of the story. Yes, they'll last longer, but safety will be compromisised.
If you want to increase tyre life without compromising safety...look at buying harder compound tyres or Light Truck tyres. Modify your driving style to suit and at least they won't delaminate at speed.
Fab.
AnswerID: 473528
Reply By: Seakarvan - Thursday, Dec 29, 2011 at 10:49
Stay well clear of tyres 5/6 years old plus. Check on the facts mate.
It's not only false economy but can stuff up a holiday - big time.
A blow-out on your 4X4, caravan or boat trailer at freeway speeds is more dramatic than a Bandag chucking a tread with 30 odd wheels as back-up.
Seakarvan
AnswerID: 473535
Reply By: Madfisher - Thursday, Dec 29, 2011 at 13:46
We can not wear the Cooper ATrs on the back of SWMBO jack out but are very dicy on roundabouts. Complained to local Cooper dealer and he showed me how to check the age. Turned out they where 6 years old. They where on the vehicle when we brought it three years ago and still have 5mm of thread.
Cheers Pete
AnswerID: 473552
Reply By: Begaboy - Thursday, Dec 29, 2011 at 16:53
Thanks for the replies everybody - some valuable information in all replies - The reason i have asked is that i live rural and as a result i have a lot of dirt roads to travel - i do about 60 KM of dirt to /from work - i have coopers on my Patrol and so far these have lasted the longest - ( put on xmas last year and a little past half worn now ) , but on average i get about 1 year out of tyres or less than 30 000 Km which is VERY short of the claimed 80 k coopers say - i am very mindful when i drive - ie gentle into and out of corners - I am getting even wear - so balance/ alignment is good and always checked anyway
Guess i just have to factor in $1500 a year for tyres on top of the $1.60 Pl diesel
could be worse though --- i could be driving a Prius LOL
AnswerID: 473560
Follow Up By: Fatso - Thursday, Dec 29, 2011 at 19:13
Oh now you've upset me Begaboy.
I've got 2 priuses.
Fatso :-(
FollowupID: 748411
Follow Up By: Begaboy - Friday, Dec 30, 2011 at 17:26
the laughs were not loud enough after you purchased your first one ??
all joke mate -- they are a very capable little city car - :)
FollowupID: 748458
Reply By: p_marns - Thursday, Dec 29, 2011 at 21:38
Mate if i only got 30k out of a set of tyres i think i d jump off a cliff. I bought a set of Maxxis AT which are cheap as. 65k ago and they are stil going strong
AnswerID: 473578
Follow Up By: Begaboy - Friday, Dec 30, 2011 at 17:28
How much tar and how much dirt driving you do though - the vast majority of mine is on dirt and clay/sand so very abrasive
FollowupID: 748459
Reply By: robert s4 - Thursday, Dec 29, 2011 at 21:59
a mate of mine his dad is a owner driver and he does it for semi and has for years must work
AnswerID: 473579
