HF RADIO BRACKET
hI ALL
I hope youall can help with a problem i about to have when i change vehicles. I am retiring the Prado from towing duties and have purchased a Ford Falcon RTV ute with a canopy It has HD roof bars. My problem is i have a HF radio aerial and i do not have a bulbar or rear bumper to mount the large aerial for the HF radio, Has anyone have a bracket for the RTV to mount or know where i could buy one
Terry
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
Reply By: Member - Tezza Qld - Friday, Dec 30, 2011 at 21:07
Hi Terry
All I can think off is a bracket welded to a nudge bar or bullbar.
There is nowhere at the rear if it's a styleside ute.
Your Prado photo shows a tap whip mounting.
Other thought would be a firecracker aerial mounted on a fold down mount on the roof bar. Bushcomm do these aerials along with others with a short tap base and flexible tuning wire.
If you mainly use 8022 and 7899 these could be on one tap
Cheers Teza
AnswerID: 473654
Reply By: Member - Phil B (WA) - Saturday, Dec 31, 2011 at 07:34
Hi Terry
You said you're retiring the Prado from towing duties. Does that mean you will still be towing, if so why not make or get made a bracket that bolts onto your tow-bar.
It may be in the way nearer the ball so why not use the tow bar further out - utilizing the tow bar extremities in some way may be the way to go.
Or you could but the bullet and get a bull bar.
AnswerID: 473669
Follow Up By: racinrob - Saturday, Dec 31, 2011 at 08:04
SB, most of the HF aerial mounts on utes I've noticed in the HF Radio Club are custom made and attached to the loading bar directly behind the cab. Or as Phil B says, another option is on the towbar like police cars in the NT.
rr VKE237 6678
FollowupID: 748490
Reply By: snailbait (Blue mntns) - Saturday, Dec 31, 2011 at 11:08
Thanks all for your
I have a NGT and a Codan multi freq aerial i will look at BushcomThanks
Terry
AnswerID: 473682
