Trailer Plug wiring problem
Submitted: Thursday, Dec 11, 2003 at 10:17
ThreadID: 9099 Views:5528 Replies:8 FollowUps:1
I have a problem with my trailer left hand indicator. The indicator
has been tested on another vehicle and works. When I connect
the trailer to my ute, the left hand indicator on the trailer fails to operate.
The ute indicator works with or without the trailer connected.
Any Ideas?????? I have checked that wiring running into the 7 pin connector on the ute. All seems ok. Where else should I be checking?
Jason
Reply By: Member - Kim (mr) - Thursday, Dec 11, 2003 at 10:21
Have you tried another trailer on your ute.Just a little puddle we found down in Gembrook
AnswerID: 39942
Reply By: Shaker - Thursday, Dec 11, 2003 at 10:26
Try cleaning or expanding the relevant socket/pin!
AnswerID: 39944
Reply By: Shaker - Thursday, Dec 11, 2003 at 10:27
Try cleaning or expanding the relevant socket/pin! Also test it with a test light.
AnswerID: 39945
Reply By: Member - ramp - Thursday, Dec 11, 2003 at 10:49
hi jason, i agree with shaker as i have the same problem with that pin,but on a mates car i found the problem to be the connection from the rear tail lite to the car plug hope this helps cheers rob
AnswerID: 39947
Reply By: Mike - Thursday, Dec 11, 2003 at 11:18
The first thing I would check is the earth. If you don't have an effective earth, the lights will do all sorts of weird things.
Happy trails, Mike.
AnswerID: 39950
Follow Up By: V8troopie - Thursday, Dec 11, 2003 at 14:01
Ditto that, its usually an earth problem since the return connection goes through the light mounting screws and trailer chassis to wherever you have connected the earth common from the trailer cable. Do not relay on an earth connection to the car via the tow ball, this is really causing odd symptoms.
Other possible causes: poor contact to the light bulb, especially those long tubular ones. The filament of these is soldered to the conical end caps and I had one or two where this connection was very intermittent.
Poor current flow due to tarnished contacts in the trailer plug/ socket. Unless these are connected and unplugged frequently the brass contacts tarnish. I have to clean those on my garden trailer every time I use it since this is not a frequent event.
Klaus
FollowupID: 257582
Reply By: Big Trev - Thursday, Dec 11, 2003 at 20:15
Make sure your 7 pin plug isn't wired up as a 5 pin plug. Yhis can sometimes and causes problems.
AnswerID: 39984
Reply By: hoyks - Thursday, Dec 11, 2003 at 21:09
If trailer lights work on a nother vehicle and your vehicle lights work, check where the wire to the plug on the vehicle is spliced into the indicator circuit and the conection in the plug.
AnswerID: 39996
Reply By: Treading Lightly - Friday, Dec 12, 2003 at 10:13
Hi Jason,
Sometimes the pin in the socket can work loose in the body and when pushed home into the relevant plug the pin is also pushed back therefore not making contact. Push the relevant pin/socket and check for any movement back into the housing.
JDLife is to good to be dead.
AnswerID: 40042
