Question: Trailer Wiring Diagrams
can anyone tell me how to wire a license plate light - the trailer is fully wired and ok except it doesn't have a license plate light. thanks
Reply By: Member - Ed C (QLD) - Saturday, Jan 07, 2012 at 16:36
Just tap into the tail light circuit (brown wire), and Robert's your mother's brother....
Confucius say.....
AnswerID: 474292
Follow Up By: IAIN M1 - Saturday, Jan 07, 2012 at 16:39
Thanks Ed, so i assume i just take it from the tail lights, do I need a single wire from one side or both, loop from one or....? thks
FollowupID: 749226
Follow Up By: Member - Ed C (QLD) - Saturday, Jan 07, 2012 at 17:03
A feed from either (closest) of the lights will be fine..
Connect one wire to the brown, & the other to white (earth return)
This is assuming the trailer is wired w/- standard trailer cable, and in accordance with the recognised standard..
Standard wiring diagram(s) can be found here
Confucius say.....
FollowupID: 749227
Follow Up By: IAIN M1 - Saturday, Jan 07, 2012 at 17:09
Fantastic, thanks Ed
FollowupID: 749228
Reply By: Member - Carl- Saturday, Jan 07, 2012 at 17:30
Image Could Not Be Found
If you are doing it with LED lights ( perhaps you might be changing over from bulbs) then Supercheap have a set that includes the number plate light as part of the tail lights. Just move the number plate position to under the park light. This might be easier?
AnswerID: 474298
Follow Up By: IAIN M1 - Saturday, Jan 07, 2012 at 17:37
Thanks Carl, they're not LED but i was thinking about that anyway. Unfortunately the tail lights are on mounts outside the body of the trailer rather than on the tailgate so I don't think that will work, tho perhaps moving the tail lights might be the easiest solution. Iain
FollowupID: 749231
Follow Up By: rumpig - Saturday, Jan 07, 2012 at 20:34
be careful if your are looking at moving the lights, there are regulations with regard to where the lights need to be mounted. you'd probably need to search the National Code of Practice for building light trailers to find out exactly what the legal requirements are in regard to this matter.
FollowupID: 749246
Follow Up By: Nomadic Navara - Saturday, Jan 07, 2012 at 22:33
For trailer lighting see - VSB-01 sect 13
FollowupID: 749258
Follow Up By: IAIN M1 - Sunday, Jan 08, 2012 at 11:12
Thanks for all this help, i think I've got it worked out - fingers crossed!!
FollowupID: 749296
Reply By: IAIN M1 - Monday, Jan 09, 2012 at 09:41
hey guys, got it done yesterday, seems to work fine - thanks for all your help. iain
AnswerID: 474445
