Water tanks
Submitted: Sunday, Jan 15, 2012 at 17:03
Ron and Lorraine P
We are new to the off road scene and are setting up our car for a trip up north in May. We are now looking at suitable
water tanks to install. We have a Triton Twincab 4x4 and are looking at
water tank to fit on the floor in the passenger area. Does anyone have recommendations of suitabale type of tanks and any feedback good or bad.
Reply By: Member - Royce- Sunday, Jan 15, 2012 at 17:16
Sometimes it's just easier to have a heap of 2 litre soft drink bottles stashed strategically.
If you hole a
water tank you lose the lot.
It all depends on how much outback stuff and travel you intend to do and how much space you want to take up... maybe permenantly.
474981
Reply By: Member - Richard H - West NSW - Sunday, Jan 15, 2012 at 17:29
I got two of the olive drab military type 20 litre
water containers at a disposal store. They don't leak and are easy to pour from. They have two screw tops, one big & one small.
I have the same type of vehicle as you do, and I find that they'll stand behind the
seat quite
Of course if you can get the proper military one, all the better. Sometimes they are available.
I also use plastic juice bottles put out by
Berri for rain
water. They are small enough to shove into tight
places and if one does split and leak, what the hell?
474985
Reply By: Motherhen - Sunday, Jan 15, 2012 at 17:31
Hi Ron and Lorraine
Questions, not answers. What amount of
water do you want to carry? How will you fill it? How will you access it? Why not carry two or three 20 - 25 litre plastic jerry cans in the tray? This can be supplemented with collapsible 20 litre
water cans which take up next to no space when packing, but can be used for times when extra
water needs to be carried. Any spillage in the tray will be less damaging too.
474986
Reply By: Member - Frank P (NSW) - Sunday, Jan 15, 2012 at 17:31
We had an unsatisfactory experience with one of those bladder tanks - fairly expensive it was, too. Over $200 for 70 litres, if I recall correctly, but that was before the high dollar.
We put padding over anything sharp or hard that it might rub against (
seat runners, etc) but that wasn't the problem.
We could not get rid of a kink in a crease - the
water forced the thing to take a certain shape, creating the crease and kink. In transit the
water sloshed about, working the crease and the kink and eventually the kink sprang a leak.
Not happy.
Frank
474987
Reply By: Member Andys Adventures - Sunday, Jan 15, 2012 at 17:34
Hi Ron and Lorraine, I have a Triton cab/c and have a 60lt
tank under the
camping pod, might have a look to see if one would fit under the car instead of in it. They can be bought on ebay. But 2/20lt plastic containers would fit in the passenger area as they fitted in my old Triton twincab.
Andy
474989
Reply By: Ron and Lorraine P - Sunday, Jan 15, 2012 at 17:46
Thank you for your tips and also sharing your experiences. We will take all of your comments on board. Great ideas!
474992
Reply By: Member - Carlin - Sunday, Jan 15, 2012 at 17:56
Reply By: Andrew & Jen - Sunday, Jan 15, 2012 at 20:01
Hullo Ron and Lorraine
The key question for me is how are you going to secure anything heavy in the cab so that in the admittedly unlikely (hopefully) event of an accident, they don't kill or seriously injure you.
My strong suggestion would be to put them in the tray - see www.enmachind.com.au (no affiillation) for a range of strong, food quality fitted tanks. We have one 65L
tank with a sloped back that fits snuggly against the cargo barrier in the back of the LC and fitted a hose and tap.
Andrew
475009
Follow Up By: rumpig - Sunday, Jan 15, 2012 at 20:52
pretty much what i was thinking also about the securing it in place incase of an accident. the last thing you want is 45kgs coming through the back
seat at you during a crash.
749980
Follow Up By: Ron and Lorraine P - Monday, Jan 16, 2012 at 19:28
Great tips - thanks so much. We didn't think of that! I will check out the site you suggested. We were just thinking about ease of filling the
tank. How easy would it be in the back to fill the
tank?
750069
Reply By: Member - Alastair D (NSW) - Monday, Jan 16, 2012 at 07:04
Ron & Lorraine,
In my early 4wd days when money was very limited in my pocket I made a light plywood box into which I stacked 10L plastic containers. This was cheap, the box protected the light containers, the
water was not all in one
tank and it was easy to make to fit into my then Landrover. I still use 10L containers sometimes to top up my total capacity when going into dry regions. They are also much easier on the back when lifting out of a vehicle. 20kg vs 10kg.
475046
Reply By: vk1dx - Monday, Jan 16, 2012 at 09:29
Like a lot of others we started out with a couple of 10 litre plastic
water containers and gradually after we worked out our own
water usage either got rid of one or got a third.
Now we have a long range
fuel tank under the car which also holds 55 litres of
water is a separate chamber. We added a pump to raise the
water to a convenient place near the tailgate. We still retained the standard low level outlet in case the pump failed, which it shouldn't as it really cost a quid. As an emergency we carry a 10 litre bottle in the car as
It will be a growing solution for you. Don't do any heavy or irreversible engineering until you are sure of what you want. A few plastic containers in the back may be all that you need.
475053
Follow Up By: Ron and Lorraine P - Monday, Jan 16, 2012 at 19:30
Thank you so much for your info.
750070
Reply By: Farms - Monday, Jan 16, 2012 at 10:28
we have a Triton and have removed the rear seats and put a board in its place to increase storage. We use a Flexitank
water bladder in the rear
seat footwell. It holds 70 litres of
water and the hose that comes with it is easy to use as long as you dont let the air get back into the hose.
It needs to be filled once inside the car so care is needed when filling. I use normal hose fittings to do this. The garden hose needs to be run for a while to clear the old
water from it before filling the bladder.
As someone else suggested, it pays to pad the front
seat floor runners.
It is a good aetup because the weight is kept to one of the lowest points in the car. We have used it twice, once into the
Simpson Desert, without any problems.
Good luck finding your solution.
475064
Follow Up By: Ron and Lorraine P - Monday, Jan 16, 2012 at 19:31
Great idea! Ron is worried about punctures.
750071
Reply By: Member - John and Val - Monday, Jan 16, 2012 at 11:57
Strongly agree with what others have said - since you are new to this off road scene hold off doing any permanent installation until you have evolved your pattern of travelling and particularly your
water use/needs. This may take a few trips, but thats OK. Finding out what works is half the fun of this type of travel.
If you plan to travel in outback areas you will find that the quality of
water that you can get will vary a lot. You do not want to be putting it all in the one
tank - not having all your eggs in one basket. For this reason we have several containers including 10 of 3l juice bottles which we fill at every opportunity, discarding poor quality
water if something better is available. We also have a 20l container and a
water tank in the trailer and have never been short of
water.
Val
| J and V
- Albert Einstein
475074
Follow Up By: vk1dx - Monday, Jan 16, 2012 at 13:52
Hi Ron and Lorraine
Val and John's real problem is making enough room for
water after all the wine goes in the car. But that's another story.
Hi Val
750030
Reply By: dieseltojo - Tuesday, Jan 17, 2012 at 17:32
Hi Ron and Lorraine P,
I Fitted a 60 ltr caravan
water tank vertically behind the passenger seats attached to a steel divider. I installed it vertically with a pump and could spray
water 6 meters if required.
Being a plumber helps but it is not hard.You can put the pump on the floor and run a hose to the bottom of the
tank through the top
tank inlets.
It is handy in case of a fire and you can rig it up as a shower. The power was from the cig lighter and had no problems.
The only thing I can say against it is the sound of the
water splashing in the
tank going over
sand dunes.
475213
