Friday, Jan 20, 2012 at 14:35
Don't worry about the insulation thickness. You can't alter it.
I gave examples as to how you can improve the performance of the fridge irrespective of the thickness, because it is the performance which is what you need to know, not how thick the insulation is.
I focus on the realities of the problem.
In house fridges the thickness is far less than older models but the insulation performance is far better.
So the thickness is totally irrelevant, it is about what it does for you.
The question to ask here is: What type of insulation is used and what is its thermal coefficient.
The ENGEL fridges have what is called a "swing" motor. If you are comparing fridges then this swing feature is called something it is not. The motor, so called, is an oscillating motor, nothing swing about it at all. It is basically a solenoid which flicks back and forwards by electronic command, same as a solenoid. This drives a piston which pumps gas.
Ross M
750444
