Digital Voltmeter - recommendation needed
Submitted: Sunday, Jan 29, 2012 at 14:16
Member - Brian A (NSW)
I'm in need of a digital voltmeter to assist with monitoring my camper trailer battery status.
I've searched the web and as yet haven't found much.
Can anyone make a recommendation. I would prefer a back lit LCD or LED display.
Thanks in advance
Brian
Reply By: Member - Fred B (NT) - Sunday, Jan 29, 2012 at 14:34
Brian,
where do you want to locate it - trailer or tug? Close to the battery as possible is best. Look at
baintech.com.au
I use a universal power socket with built in digital voltmeter and three power outlets.
If you want more than just voltage..., you will probably have to go with a power management system... More $$$$. But take a look at baintech, they have lots of stuff.
regards
476294
Reply By: Dave(NSW) - Sunday, Jan 29, 2012 at 14:36
Try here www.sidewinder.com.au
Cheers Dave
476295
Follow Up By: Member - Brian A (NSW) - Sunday, Jan 29, 2012 at 15:32
Thanks Fred and Dave. Appreciate your replies.
The Baintech looks best suited for surface mount - in the camper battery compartment.
Brian
751318
Reply By: Rangiephil - Sunday, Jan 29, 2012 at 16:20
jaycar do a small digital voltage meter with also an in and out temp display and clock for AFAIK about $39.
I have had one for 12 years now and it is still going strong. although the clock has given up, and it is accurate within about 0.1 volt.
I recall it was used by a camper trailer manufacturer at one stage.
Regards Philip A
476304
Reply By: Member - Rob D (NSW) - Sunday, Jan 29, 2012 at 17:26
Sidewinder ABR have a cigarette lighter voltmeter which is very convenient, accurate and inexpensive (less than $20 I think).
I have one in my Ultimate camper and can check the voltage whilst inside of the camper.
476311
Follow Up By: Member - Brian A (NSW) - Monday, Jan 30, 2012 at 13:11
Thanks Phil & Rob.
Appreciate your input.
Brian
751420
Reply By: The Bantam - Monday, Jan 30, 2012 at 00:38
I find it fascinating that you can buy a fairly respectable digital multimeter for less than $20 these days, but be buggered if you can get a decent basic digital voltmeter for that.
However
Not long ago Jaycar/ Electus braught out the QP5586 self powered led digital voltmeter, and matching ammeter.
these come for arround $25 retail.
I've been running one of these stuck to the top of my fuse box for a a few months now and it seems to be a reasonable thing..it seems accurate compered to my better multimeters and is still going.
The only beef I have is that it is LED and ya cant dim the display so, not the best for in dash.
but reasonable and far more affordable than other digital pannel metters than have come to market thus far.
I've played with the clock / thermometer / voltmeters, and they are crappy things and cant be easily flush mounted, although they are reasonable accurate.
476350
Follow Up By: Member - Brian A (NSW) - Monday, Jan 30, 2012 at 13:18
Thanks for this Bantam.
My sentiments exactly. Amazing how you can buy a multi meter for 20 or 30 bucks, but have difficulty purchasing a single use meter for the same money. I have previously had the earlier version of the Jaycar meter, but it required a separate power source. One day the "smoke got out" and it is no more. I shall give the new version a go and see what happens.
Brian
751423
Reply By: Nomadic Navara - Monday, Jan 30, 2012 at 14:30
Another company worth a look at is
http://www.12volt.com.au/
476384
Follow Up By: Member - Brian A (NSW) - Tuesday, Jan 31, 2012 at 21:07
Thanks Peter.
Just had a look at their site. It looks like they have some quality gear.
Brian
751618
Reply By: rapid80 - Saturday, Feb 04, 2012 at 20:25
I recently fitted a Projecta digital dual volt meter and found it to be a good little unit. Very compact but has a clear display for 2 battery voltages.
476886
