NP Pajero rear a/c problem
Submitted: Tuesday, Jan 31, 2012 at 00:24
jt
Hi all i have a NP Pajero exceed the rear a/c is blowing warm air out the rear vents have checked all switches and all with in spec of the manual the local a/c guy said it maybe a solenoid I can not find one any where is anyone had this problem before or does anyone know where the solenoid is.
Thanks.
Reply By: olcoolone - Tuesday, Jan 31, 2012 at 20:49
It could be a number of things and there are no common issues....
1) Solenoid could be faulty.
2) TX valve could be faulty.
3) Thermostat/thermister could be faulty.
4) Wiring issue.
5) Amplifier or component issue.
6) Fuse.
7) Kinked or damaged liquid line.
8) If rear heater fitted faulty heater tap.
9) Blocked evaporator fins.
If you local A/C guy is any good he should be able to diagnose it and obtain information needed to repair.
476517
Reply By: Member - Gordon T (NSW) - Tuesday, Jan 31, 2012 at 23:08
Suggest you pose the question or search on the Pajero
Forum (Pajero 4WD Club of Victoria) - if it is not there or one of the members doesn't know about it then it hasn't happened yet. The site is full of valuable information for Mitsubishi (& Pajero) owners.
476542
