Airconditioner for fifth wheeler
Submitted: Thursday, Feb 02, 2012 at 12:36
Lee 64
I am looking at a 37' 5th wheeler and want to put another aircon in it as the previous owners have said it struggles with the one it has in it at the moment. Could I have some feed back from the experienced as to what I should be looking for and generally how much they cost?
I am a true novice I am afraid and any info would be greatly appreciated.
Reply By: Member - Tony (ACT) - Thursday, Feb 02, 2012 at 18:52
Maybe look at an upgrade to a bigger unit the the one you have got.
476680
Follow Up By: Lee 64 - Friday, Feb 03, 2012 at 09:41
Thanks Tony.
So you think I should replace the one I have.
I thought I could add another one as
well seeing as the existing unit still works. Double the effect as I have seen the new 37' 5th wheelers with 2 units. Would that not work?
751892
Follow Up By: Member Boroma 604 - Friday, Feb 03, 2012 at 10:14
Gooday,
Would suggest you look at the possibility of installing a Domestic Inverter split system, know a lot who have done this with their caravans. They are much quieter, will run off a 1 Kva generator and far more efficient.
If the existing one is a roof top you may be able to remove it and replace it with a 4 seasons Hatch.
Boroma 604
751900
Follow Up By: Lee 64 - Friday, Feb 03, 2012 at 11:23
Thanks Boroma 604,
Thats sounds like a good idea but I was wondering where would the outside fan unit go? I think they are quite large and the 5th wheeler is a goose neck. Any ideas about where to mount it?
751908
Follow Up By: Member - Tony (ACT) - Friday, Feb 03, 2012 at 15:08
My thoughts are it maybe easier to replace the current unit than find somwhere to put a second one.
751920
