mounting solar panels
Submitted: Friday, Feb 17, 2012 at 17:59
wallabyjack5
I'm thinking of mounting solar panels on the roof of our caravan but would like to raise them when we are stopped for the best performance,would also like to be able to follow the sun.
One idea I had was to use the type of
TV antenna that you wind up and turn to be able to follow the sun.
Has any body tried this or is there a better solution
Glyn
Reply By: mikehzz - Friday, Feb 17, 2012 at 18:25
It means you always have to
park your van in the sun. Also, you have to make sure you have the right type of cell because if shade hits any part of one of the types (mono or poly...I forget) then all the charging stops. Cheers.
478027
Follow Up By: Member Andys Adventures - Friday, Feb 17, 2012 at 19:44
Hi mikehzz,
Only if you like sitting there turning the handle every 6 min to follow the sun. I lay
mine flat and have no problem. If you need to chase the sun you should get another panel to give you the extra power you need.
Andy
753451
Follow Up By: Member Andys Adventures - Friday, Feb 17, 2012 at 19:46
Sorry that should have read wallabyjack not mikehzz.
Andy
753453
Follow Up By: wallabyjack5 - Friday, Feb 17, 2012 at 22:55
Thanks Andy you are prob right maybe cheaper too.
Glyn
753476
Reply By: 4X4Treker - Friday, Feb 17, 2012 at 20:16
wallabyjack5 its all about amp hours out against amp hours back into your batteries, I am currently using two 110watt panels fixed flat to the roof of my new caravan but I also reduced the overall load by having it fitted with all LED lighting and only use the inverter when needed. Only done one trip away for two weeks with it and it was mixed with overcast days and full sun days but never looked like having any low power problems and that was all
bush camping in the one spot with no mains power.
Rule of thumb for me has always fit as many panels as you can and as big as you can with the right solar regulator batteries will never be overcharged but more importantly your batteries will last longer as they will be topped back up to max each day regardless of sun conditions.
I have room for one more panel on the roof but at this stage my daily discharge is no where near draining the batteries to harmful levels.
Treker
478032
Follow Up By: wallabyjack5 - Friday, Feb 17, 2012 at 22:50
Thanks Treker for that info,could you please tell me what LED you use for the main inside lights and what batteries you have.
Glyn
753474
Follow Up By: wallabyjack5 - Saturday, Feb 18, 2012 at 23:35
Thanks for that Treker great lot of info
Glyn
753558
