Big Red to poeppels corner
Submitted: Saturday, Feb 18, 2012 at 19:07
ThreadID: 91945 Views:3205 Replies:7 FollowUps:20
I will be in birdsville around the 21st of august 2012 and would like to know if any one else will be there around the same time and would like to tag alone on a return trip from birdsville to poeppels corner. I have never been out there before and am only travelling with my wife and two kids. i have a 2004 pajero exceed TD with a 2" lift BFG's all round and was hoping to get out to the corner and back in the same day.
If anyone is going to be in Birdsville then and would like to come to the corner let me know.
Reply By: Allan B (Member, SunCoast) - Saturday, Feb 18, 2012 at 19:18
Hi Dean, Have you looked closely at the map. It's about 300km round trip at an average of 15-20km/h. That's maybe 20 hours without stopping!
AnswerID: 478076
Follow Up By: Mark C - Sunday, Feb 19, 2012 at 15:27
Have done it in one day 12hours, bit rushed crossed big red at 10.30pm>
Better to camp over night.
FollowupID: 753625
Reply By: Member - Stephen L (Clare SA) - Saturday, Feb 18, 2012 at 19:20
Hi Dean
I don't want to sound like a know all, but a very big ask from someone that has never been out in the desert before. It may not look like very far on a map, but it is a good days drive one way with sand experience.
Treat your family to the best time of their lives and spend a few days out in the desert, it will be an unreal experience for you all. You will have many people telling you different things, but the best bit of advise where you can not go wrong for a first time traveller, drop your true to 14psi and you should have no problems at all.
It is not a race, make regular stops to admire the scenery, you will be amazed at what is out there. Your vehicle will have no problems, the diesel will make easy work of it.
Make sure that you extra water with you and a bar minimum of a long handle shovel, Maxtrax ever better.
I have a few blogs about our Simpson adventures if you check out my blogs.
Do not rush and you will have a great time.
AnswerID: 478077
Follow Up By: dean r2 - Saturday, Feb 18, 2012 at 20:37
i heard it was only about 6 1/2 hours each way but now hearing from everyone that has replied and been there done that i think i might pack the tent. i will be towing a jayco flamingo into birdsville from mt isa and plan on staying at the caravan park there is it safe to leave it there while i go to the corner and back overnight. i have also have 4x4 experience but not to much sand driving but i think by the time i get there i should be ok as b4 i get to birdsville i will have alread travelled from roper bar to cape crawford via the savannah way which should be fun. About tyre pressure isnt 14 psi a little low and should i keep the tyres at this pressure for the whole trip to the corner.
thank for your advice
FollowupID: 753541
Follow Up By: Member Andys Adventures - Saturday, Feb 18, 2012 at 21:20
Hi dean r2, The road from Roper Bar to Cape Crawford is just a dirt road, not sand,and could get a 2wd through there. By the sound of it you haven't done much sand driving and suggest that you have some practice in some sand dunes before going so you know what your in for, and get use to letting down your tyres to the correct psi. You will see the difference from having 30 psi to 20 psi to 16 psi in your tyres. Just try one sand dune at 30 then 20 then 16 you will see which is best. I may be out that way around late August as I will be at Birdsville races. I'm at Lorella Springs at the moment which is half way between Roper Bar and Cape Crawford, drop in on your way through.
Andy
FollowupID: 753545
Follow Up By: dean r2 - Saturday, Feb 18, 2012 at 21:26
thanks
how much fuel do you think i will need the pajero has a 90ltr tank will this be enough to go from birdsville to the corner and back. Also should i hire a sat phone for the trip or will there be enough traffic should i have any troubles
FollowupID: 753547
Follow Up By: dean r2 - Saturday, Feb 18, 2012 at 21:42
i will send you an email when i am at roper bar to see if you are still there
FollowupID: 753549
Follow Up By: Member - Stephen L (Clare SA) - Saturday, Feb 18, 2012 at 23:13
Hi Dean
By August the temperatures out in the desert will be starting to rise again, in and around the low to mid 30's during the day, with mild to cool nights - perfect camping weather.
Now for the tyre pressures.
You will find that the eastern side face of the dunes will be steeper than the western side as you head out into the desert. (my preferred crossing is an East to West crossing, better fun on the steeper dunes) There are big spacings between the swales in the eastern section of the desert, compared to further west, which you will encounter as you head in from the K1 Line and onto the French Lines, very close to Poeppel Corner. Sand conditions should be soft, but with 14psi, you will walk up the dunes no problems at all. Do not throttle off at the top of each dune, and be prepared for a quick change indirection. I have seen countless people going great up a dune, then as they near the top, back off the power, and then sit there spinning in the soft sand. Keeping momentum up will help you over the top and when you start to descend the dune, it is then safe to then just crawl down the dune.
You do not need any run ups for the dunes, either direction, less strain on your vehicle and going fast you will all be thrown into the air as you hit all the cut ups on the dune faces. I nearly always use 2nd high for all dune crossings except Big Red, but will get to that later.
You will not be going fast, mostly 3rd high, and in the longer swale spacings, into 4th. Speed wise around 30 kph, sometimes 40. At the top of each major dune - you will know about that as you travel, I would often put a call out over the UHF (Channel 10 preferred channel for a Simpson Crossing) to see if there are any vehicles heading my way. Make sure that you also have and use a Sand Flag for the safety of your family and so other vehicles can see you if they are close to you.
As you pass Eyre Creek, you will be getting into Gidgee Country, and this means usually good camping spots, and it is a great wood for campfires. One your return trip back, the dune faces will have longer run ups, but no where as steep as you will encounter on the way west into the desert.
Now for Big Red, everyone's favourite dune of the Simpson to cross. Again you will hear of every way to cross this little mother, but again steady as you go and it is easy. I do however top my pressures down to 10 psi to make the crossing easier. I never hit the dune at speed and in fact always start at the very base from a standing start in 2nd low and then go into 3rd low after take off. Again keep the power up and make your change back to second very quick, with minimum loss of momentum and do not power off until you have all 4 wheels safely on top of Big Red.
Your van will be safe in the Caravan Park in Birdsville, it is a top little park. As for fuel, 90 litres should be fine, but if you want peace of mind, then an extra 20 litres would be all that is required, as you are not doing a complete crossing.
Like my first reply, take your time and it will be easy to spend at least 2 nights out in our great Simpson Desert.
Have a Safe Trip.
FollowupID: 753555
Follow Up By: dean r2 - Sunday, Feb 19, 2012 at 09:06
thanks stephen for the info it should make my trip alot easier.
FollowupID: 753571
Follow Up By: Member - Blaze - Saturday, Mar 10, 2012 at 00:52
Hi Dean,
Everything Stephen has put is spot on, and if you take your time you will have a good run. Another way of doing this is to run out to Poepels and then run down the K1 and back up the Birdsville Track, saves seeing the same country twice.
One other point I didn't see in anyones response, please make sure you have a sand flag on when you go out there, I am seriously over people doing the Simpson or part of it without sand flags.
FollowupID: 755510
Follow Up By: dean r2 - Saturday, Mar 10, 2012 at 20:43
thanks blaze will have a flag with me ( a 12 foot beach rod muilty purpose)
FollowupID: 755561
Reply By: Michael A (VIC) - Saturday, Feb 18, 2012 at 20:00
Dean
From Bridsville, my other half and I have comfortably filled a day by doing a return trip out to Eyre Creek. We usually have a picnic with fresh bread from the bakery. We also spend a bit of time playing around on Big Red. Has been excellent the last couple of years with plenty of water in Eyre Creek.
The corner would be hard work.
Michael A
AnswerID: 478082
Follow Up By: Wayne (NSW) - Saturday, Feb 18, 2012 at 20:26
Michael,
I don't think your next trip out there will be a picnic.
Wayne
FollowupID: 753540
Follow Up By: dean r2 - Saturday, Feb 18, 2012 at 20:44
thanks for your advice.
how much fuel do you think i should carry the pajero has a 90 ltr tank will this be enough
FollowupID: 753542
Follow Up By: Mick O - Sunday, Feb 19, 2012 at 08:02
Dean, what are your normal fuel consuption figures for towing with the Paj (is it a diesel of petrol?)? I'm not familiar with the Paj but what ever the vehicle, you need to work on worst case consupomtion. If your avaeraging 6-7 kpl towing you need to work you fuel for the desert on 4-5 kpl and add a margin. 80 x 4 = 320 km. You'd probably make it but I'd be adding a jerry can just to be safe.
If a prado has a comparable engine size and vehicle weight/capability etc, then Stephen l. would more than likely be able to provide advice on that.
Cheers Mick
FollowupID: 753569
Reply By: AlbyNSW - Saturday, Feb 18, 2012 at 20:16
As others have said it is too far for a one nighter
What I suggest is to spend the day on Big Red and around Eyre creek then head west later in the afternoon for 45 odd minutes until you find a nice spot to camp between the dunes, set up a fire and enjoy the desert camp experience.
I know you won't have bragging rights for getting to Poeppels but you will still get the Simpson experience without the family stress of a big trek.
We have done this on a number of occasions rather than staying in Birdsville
AnswerID: 478085
Reply By: brushmarx - Monday, Feb 20, 2012 at 10:27
This really is a prime example of don't believe everything you hear (or read).
It would depend on conditions at the time, but given average conditions, it can be done with no drama's.
My wife and I did that trip in Feb a couple of years ago.
It was average temperatures for the time, fine but a bit windy (around 20 kph) from the East.
We left the caravan park about 6:15 in the morning.
Stopped for a few photo opportunities and morning tea on the way out. Had a half hour lunch at the corner, and returned.
We generally stayed in 2WD between the dunes, and went back to 4WD for the sandhills to minimise temperature buildup in the Monterey auto transmission as a precaution.
We ended up stuck on one sandhill midway back when I got too relaxed and left it in 2WD. A half hour with a shovel saw us free. After that we had a half hour afternoon tea as a break.
We hit Big Red about 6:00, and got stuck on that too.
Because of the easterly wind all day, and we were the only vehicle out there, all tracks had been covered by windblown sand, and we just took it head on. The dunes had a capping of real soft stuff. Not knowing what was on the other side of the crest meant slowing down just before the top, and I got it wrong by one metre. That one took an hour to dig free.
All up, we got back at 8:00.
Sure, it was a long day, but still worth it.
We took enough water for 4 days, emergency food for the same, some blankets if we did get stuck out there.
We had no option to going alone, except to not go.
We had the UHF and a Sat Phone, told the Ranger where we were going and when we were expecting to return.
It was a great trip, although worth taking longer if it was possible.
Our 3.5 litre Monterey (Jackaroo with gay alloys) auto did the trip on 75 litres. We took a jerrycan, and topped up at lunch time, and when we filled up next day. the tank took 55 litres. We have a small lift, and basic A/T tyres, nothing special.
We did not speed and take risks with the conditions, but also, did not sit around watching the lizards sunbake, make damper or a BBQ lunch.
This trip can be done in a day (subject to conditions on the day) and should offer no problems to a half decent vehicle and driver.
We took it as a trip we would like to return some time and take more time, but far better to do it in one day, than not do it.
Some people think a four hour drive is a long day, others can sit behind the wheel all day. Depends on the driver.
If you can't get another vehicle to go with, the worry of going it solo vehicle, with precautions, is better than watching someone else's video of the trip.
and good luck.
AnswerID: 478192
Follow Up By: dean r2 - Monday, Feb 20, 2012 at 14:13
thanks for the info
after all the replies i was thinking the same thing leave early and just see what happens if i make it i make it if not will have to camp along the way which isnt a bad thing. What tyre pressures did you run?
FollowupID: 753706
Follow Up By: brushmarx - Monday, Feb 20, 2012 at 16:39
We started with 20psi, and didn't moniter them or adjust them until we snagged the dune on the return trip in 2WD.
After the distance and the day's temperature, they had expanded to 26, so I dropped them back to 20. If I took them back to 15 to 18, I don't think we would have had any trouble on Big Red.
FollowupID: 753723
Follow Up By: AlbyNSW - Thursday, Feb 23, 2012 at 22:07
Mmmmmm, driving from 6am in the morning till 8 that night with wife and two kids = car full of unhappy campers
FollowupID: 754011
Reply By: Wayne (NSW) - Monday, Feb 20, 2012 at 17:57
dean r2,
Trying to get to the corner and back in one day?
When I,have crossed the Simpson Desert, up to 15 crossings with 2 more this year, with an average speed is 20kph. Any faster and something will go pear shape.
So at 20kph, 160 km= 8 hours one way.
I have seen two vehicles with only one rear shock in each vehicle and a roof rack rip the captive nuts out of the roof. All due to speed. The track was also a mess after they had been through.
I also drive in 4WD high range all the time while on dirt and sand, no embarrassing moments getting stuck because 4WD was forgotten to be selected.
Not sure if your vehicle is an auto or not but if it is an auto, gear selection is just as important as a manual transmission. Between the sand dunes you can go into drive if you wish but when it comes to driving the dunes bring the transmission back to 2nd or even 1st gear high range 4WD, the same as you would in a manual vehicle.
This will give you plenty of power at a slow pace. It is not how fast you can go over the dunes but how slow and steady you can be.
As for fuel take a couple of jerry cans with you, you can always use the fuel if not requird on the rest of the trip
Wayne
AnswerID: 478232
Follow Up By: Crackles - Friday, Feb 24, 2012 at 12:56
20 kph maybe in a big group but not on your own? That would take you 4 or 5 days to do a full crossing at that speed & of cousre as you already know Wayne much of that 160 km starts with high speed dirt and has inter dune sections that can be safely done at 50kph.
6 & 1/2 hours as suggested to him one way out to Poepells with a few breaks is certainly achievable. Biggest issue I see is being fully prepared for all contingencies travelling solo with no previous desert experience.
Cheers Craig..........
FollowupID: 754069
Follow Up By: Member - Krakka - Monday, Mar 12, 2012 at 10:01
Gee, we're splitting hairs here. 6.5 hrs one way, 8 hrs one way. Either way I would make it a 2 day sortie at least. Whats the hurry, not like most of us can get there every year, so make the most of it while you are out that way, to me 10 or 12 hours a day is not what I call a holiday, 2 kids in the car, I'll bet they will really enjoy 12 hrs stuck in the car.
As Blaze mentioned earlier, take a different route back to Birdsville and really make the most of it. Another great thing to do at Birdsville is to take a trip out to the Dingo Caves at sunset.
Just my two bobs worth, but for me best to make it an overnighter at least.
FollowupID: 755655
Follow Up By: Crackles - Monday, Mar 12, 2012 at 19:30
Not splitting hairs at all Pete. I'm not much at maths but the extra 3 hours return time is the difference between making it back in daylight or not. Not everyone has the same time availability & equipment when touring the desert so accurate info is what dean required to make a decision & reading the full thread he's taken it onboard.
Cheers Craig.............
FollowupID: 755677
Follow Up By: Member - Krakka - Monday, Mar 12, 2012 at 21:27
I understand where you're coming from Craig, but also remember you won't get the same daytime hours in August that we are enjoying now. Also what takes one person 6.5 hrs may take another person 8 hrs. As you know conditions change all the time. Much info here though from which to try and decide what to do.
FollowupID: 755687
Reply By: Holden4th - Thursday, Feb 23, 2012 at 21:20
I've done the Simpson in a diesel Paj in a year with very soft conditions. I used 94L of fuel between Birdsville and Mt Dare so your tank will easily get you to and from Poeppel Corner. From memory we got on to the French Line after Poeppel and only drove another couple of hours before we stopped so I'd definitely look at an overnighter.
Heading west, I found that nearly all dunes took a left hand turn just after the top (not sure why) so you can safely drive on to the top without worrying about suddenly dropping over the other side as the westwern side is less steep. West to east might need a bit more care. I had my tyres at 20 psi and this worked well for me with the Paj. The one issue you will face with the Paj is the clearance in the wheel wells as this can inhibit progress.
Enjoy your trip out to a magnificent part of Australia.
AnswerID: 478509
Follow Up By: dean r2 - Friday, Feb 24, 2012 at 12:20
thank mate very helpful. hope not to have any clearnce issues as i have raised the car bit over inchs.
FollowupID: 754059
