Error saving image - Please try again
Submitted: Friday, Feb 24, 2012 at 07:51
ThreadID: 92068 Views:2181 Replies:3 FollowUps:5
Why do I always get this message. The image seems to download and then I fill in the text, but when I go to save it I keep getting the above message.
What am I doing wrong?
If you relax at a faster pace you can get more relaxation in for a given time.
Regards Rob
Reply By: Member - Rob D (NSW) - Friday, Feb 24, 2012 at 07:53
For those of you who are not mind-readers.
I should have mentioned that this occurs when I try to add an image to 'My Profile.
Regards Rob
AnswerID: 478531
Reply By: Sir Kev & Darkie - Friday, Feb 24, 2012 at 09:16
Rob,
I had the same problem, does the file name have any of the following in it?
' ! @ # & , . etc as there is a scripting error that occurs with the system as it does not recognise the symbols. Rename the file without any symbols in it and I think it will work.
Cheers Kev
Russell Coight:
AnswerID: 478538
Follow Up By: Member - Rob D (NSW) - Friday, Feb 24, 2012 at 09:42
Hi Kev,
I tried that and it worked. You are a bloody genius, your disguise is no good any more.
Thank you very much, you have ended a period of frustration for me.
Regards Rob
FollowupID: 754044
Follow Up By: Sir Kev & Darkie - Friday, Feb 24, 2012 at 13:37
Rob,
Don't blow my cover LOL
Cheers Kev
Russell Coight:
FollowupID: 754075
Reply By: ExplorOz - David & Michelle - Friday, Feb 24, 2012 at 16:05
Rob,
What characters were in the original filename please? I made a number of changes the other week when I was first alerted to the problem and I thought I had modified the system to support them but you maybe using something I have not tested for.
David
AnswerID: 478567
Follow Up By: Member - Rob D (NSW) - Friday, Feb 24, 2012 at 16:31
Hi David & Michelle,
The original file name was 'Nolan's Brook Lo-Res'
Regards Rob
FollowupID: 754088
Follow Up By: ExplorOz - David & Michelle - Friday, Feb 24, 2012 at 16:33
Hum bloody single quote how did I miss this one - I hate them as SQLServer and javascript uses a lot of them .net does not care about them and I always get them wrong. Anyway I will add support for this and test it shortly. Thanks for the info, I will resolve this in the next day.
David
FollowupID: 754089
Follow Up By: Allan B (Member, SunCoast) - Friday, Feb 24, 2012 at 18:28
There's no end to it, is there David?
FollowupID: 754098
