Thinking of Adding a solar panel & Aux battery set up in Jayco Freedom 2001 Pop
Submitted: Monday, Feb 27, 2012 at 16:27
GLC2428
Anyone had any experience with either connecting to the Centurion 3000 converter or Upgrading/Replacing it ??
Also is all the lighting 12v running through this unit or ??
Am leaning towards replacing it with Ctek D250S and solar panel with 100 Ah AGM battery, So if I do that I assume I have to bypass/disconnect the 12v output from the Centurion so it just does the 240v when required ??
Any thoughts Appreciated..
Reply By: ozjohn0 - Monday, Feb 27, 2012 at 16:37
I can't help with the electric side of things, but remember as with all other additions the weight of the battery and the solar panels will have to be included in your personal payload allowance.
Ozjohn.
478841
Follow Up By: GLC2428 - Monday, Feb 27, 2012 at 17:23
Hmm True, maybe another way is to get a Thumper AGM Battery system say a 105ah and sit it in a cradle in the back of tow vehicle and connect it to the system when pulled up via anderson plug..
754368
